2009 Corolla Block Heater - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2009, 01:34 PM   #1 (permalink)
View caperconnection's Photo Gallery
Canada 2009 Corolla Block Heater
Does anyone out there know where the strange looking block heater is installed, I hate to spent $100 in labor at the dealer to install it. All I know it does not go into the coolent
caperconnection is offline   Reply With Quote
Old 02-08-2009, 02:12 PM   #2 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $520719
View LeanBurn's Photo Gallery
Canada
I am pretty sure it goes to the coolant. It will attach directly to the block somewhere, usually in the back. Did you follow the cord?
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 02-08-2009, 04:42 PM   #3 (permalink)
djb383's Avatar
View djb383's Photo Gallery
Seems like warm oil would be better than warm water.......and there's no chance of a leak with a pad heater.
http://www.padheaters.com/
XLE in the fast Barcelona Red - Yep, it's got a HEMI
djb383 is offline   Reply With Quote
Old 02-08-2009, 06:56 PM   #4 (permalink)
There is no block heater in it, There are no freeze plugs in the block. If you look up a block heater for a 2009 Corolla you will see why I am asking the question. It does NOT go into the coolent.
Old 02-08-2009, 07:23 PM   #5 (permalink)
djb383's Avatar
Your original post sounded like you already had the part but you didn't want to spend the labor $ to have it installed.
Old 02-08-2009, 08:22 PM   #6 (permalink)
View forresta's Photo Gallery
no, no, no. It goes to tires so they will grip better from the start :P
Seriously, Is a block heater as simple as plugging it into the chassis on the new cars?
forresta
forresta is offline   Reply With Quote
Old 02-08-2009, 08:32 PM   #7 (permalink)
djb383's Avatar
A block heater attaches to the engine block (not the chassis) and heats the engine coolant. A pan heater attaches to the oil pan and heats the lubricating oil.
Old 02-08-2009, 08:36 PM   #8 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
The block heater for the 2009 Corolla slides into a cavity on the driver's side of the engine above the transmission. It does not heat the coolant or the oil, it heats the block.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 02-08-2009, 09:19 PM   #9 (permalink)
LeanBurn's Avatar
Canada
Wierd. That's a first for me...
Old 02-09-2009, 01:01 AM   #10 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
good to note. Makes more sense imo. Any idea on the wattage? Just that I know the diesel vw guys are running a 1000w recirculating pump that warms the motor up nice and toasty in 2-3 hrs from the deep freeze.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 02-09-2009, 06:57 AM   #11 (permalink)
I have a VW TDI and I installed one of those heaters in mine because VW does not have a heater for the TDI, Take the time to look up the heater for the corolla you'll see what I mean
Old 02-10-2009, 06:26 PM   #12 (permalink)
Thanks Jeff
I'll try and locate the spot. Are there any special precautions when installing the heater
Old 02-10-2009, 07:07 PM   #13 (permalink)
Jeff Lange's Avatar
Not really, just make sure you put the thermoconductive grease on the heating element, and route the cord away from any moving and/or hot engine components.
Jeff
Old 02-11-2009, 08:48 AM   #14 (permalink)
djb383's Avatar
Can you post some pics of the install?????
Old 02-22-2009, 03:42 PM   #15 (permalink)
LeanBurn's Avatar
Canada
Does anyone know if this block heaters have a built in thermostat? ie They only run when the the ambient air gets below a specified temperature.
The reason I ask this is because at around zero it doesn't seem to have an effect on the warm up time (when I start up it seems to be below the "C", where as -10c it seems to almost start off on the "C")
