Wind Noise!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2009, 08:58 PM   #1 (permalink)
View 73monte's Photo Gallery
Wind Noise!!!!!!
I've posted this before, but it's getting to the point that it's driving me so nuts, that I've got to try again to see if anyone has had this problem, or has found the cure.
Mine is coming from the drivers side. Seems like the window. The dealer has already replaced the door seal, and that did nothing. There's a whistling sound accompanied by the wind at the side window. It's an 09, and has 15,000K on it.
I've tried taping the window from the outside and putting weatherstripping in the door channel. Nothing works.
Thanks to anyone who can give me the fix for this. Open to suggestions.
73monte is offline   Reply With Quote
Old 02-14-2009, 09:06 PM   #2 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $520719
View LeanBurn's Photo Gallery
Canada
IDK. Are you sure its the window and not the mirror cutting throught the air? try folding the mirror in and see if the sound changes.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 02-14-2009, 09:45 PM   #3 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
it could also be coming from the front passenger side or the moonroof if there is any.
joeylgarcia is offline   Reply With Quote
Old 02-15-2009, 01:41 AM   #4 (permalink)
Magnetic Grey
Corollanation's Avatar
View Corollanation's Photo Gallery
Um driving 65+ mph with a folded mirror? hehehe mine whistled but no I don't think I hear it..
Corollanation is offline   Reply With Quote
Old 02-15-2009, 07:44 AM   #5 (permalink)
View Dorkinheimer's Photo Gallery
Maybe your door isn't well adjusted and doesn't shut properly.
Maybe your window goes up to the top but not equally, so a bit of air is penetrating and making that sound.
Try lowering your window a millimeter at a time and see if the sound changes. Then you'll know that it comes from there.
Dorkinheimer is offline   Reply With Quote
Old 02-15-2009, 05:08 PM   #6 (permalink)
I've tried everything except the mirror fold in. I will give that a try next. If it is indeed the wind coming off the mirror, how the heck can you fix that?
Everything seems sealed well enough. Could it be coming through the inside of the door somehow? Maybe sound proofing would work.
Old 02-15-2009, 07:12 PM   #7 (permalink)
ernest t bass's Avatar
View ernest t bass's Photo Gallery
I have the same problem.
when i push on the window it gets worse.
ernest t bass is offline   Reply With Quote
