Just letting you know, the ABS speed sensors also provide the speed signal to the engine ECU and speedometer, as well as the electric power steering computer. Not sure what pulling the ABS fuse would do to the rest of the vehicle. Chances are your speedometer would no longer function, and you'll probably have funky things happening with steering assist.
Not 100% sure though, because there are 3 power sources to the ABS ECU, 1 from the ABS No.1 fusible link, one from the ABS No.3 fusible link and one from the ECU-IG No.1 fuse, so who knows, the power from ECU-IG may allow the speed signal to still get generated.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
