I own a 09 1.8L Vibe which uses the same engine and transmission as corolla/matrix made by
toyota
nummi. I also notice the oil consumption problem.
However, I think that I find the reason.
The car has 3-D, 2, L. I always assumed it meant 3=D, and there's nothing in the owner's manual to suggest otherwise.
But it is not ture. "3" and "D" are two different gears. You can bump the lever to the right to get into D, and bump the lever to the left to get into 3.
When I use "3", the engine is noisy, especially when the speed is more than 80km/h, and the RPM is always between 3000-4000 or even higher, which I think made the engine consume more
engine oil
(High tempreture and High RPM). Also, the mileage is poor.
When I use "D", the engine is quite, especially when the speed is more than 80km/h, and the RPM is always between 2000-3000 which I think made the engine consume less engine oil (Low tempreture and Low RPM).
And the mileage is good.
I may be stupid. I noticed the difference between "3" and "D" after driving my car for more than 2500 km (2000 miles). Before that time, most of the time of driving, I was using "3" instead of "D". So I had a oil consumption problem and poor mileage on my vibe 09.
Now, I am using "D" gear during my driving, the oil consumption problem seems gone and the mileage is really good now.
I hope my experience can help others.
Any comments are welcome.
