Rear Deck Panel Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2009, 09:45 AM   #1 (permalink)
View James Here's Photo Gallery
Has anyone successfully removed and reinstalled the rear deck panel? I am talking about the large plastic piece in between the rear window and rear seat... that houses the third brake light and rear speakers.
As the "S" and "XRS" owners (with factory installed spoiler) know, there is no actual third brake light inside the car. Well, the dummy filler plate in place of the third brake light has popped loose and moves around/makes noise. How annoying...
...any help/tips on removal of this rear deck are appreciated.
Thanks.
James Here is offline   Reply With Quote
Old 05-08-2009, 11:37 AM   #2 (permalink)
View nielsenj's Photo Gallery
I just did it last week.
I started by removing the pillars, unfasten the clips and you can pull it up and out from beside the deck.
I then losened the lower black plastic panel to the right and left of the rear seats (the lower plastic panel surrounding the opening).
This allowed me to remove the upper black panel pieces to the right and left of the rear seats.
Once these were off i made sure i moved the seat belt out of the chanel in the panel and proceeded to unclip the back panel.
There are two clips (from my recollection) in the center of the deck, i found prying up on the front edge slowly and gently made them come out.
Once it's uncliped the deck comes forward/up and out fairly easily.
Would show pics but it was a last minute thing, took 5 mins or so and i didn't take any.
Regards,
J
nielsenj is offline   Reply With Quote
Old 05-10-2009, 08:23 PM   #3 (permalink)
I thank you!!
Old 08-27-2009, 08:59 PM   #4 (permalink)
View scottewalker's Photo Gallery
by any chance did you take pictures? I want to disconnect the 3rd brake light becasue I installed a spoiler.
scottewalker is offline   Reply With Quote
Old 08-28-2009, 01:01 PM   #5 (permalink)
Pie
View Pie's Photo Gallery
Regards,
J
Yup, gotta start with the pillars. I just pulled on the parts and everything came apart
Pie is offline   Reply With Quote
Old 09-04-2009, 06:59 PM   #6 (permalink)
Pie,
Did you start with pillar that has the SRS Airbag on it (beside the rear glass)? I have a hard time starting there thinking I might mess up the airbag system.
Old 09-04-2009, 07:12 PM   #7 (permalink)
Pie
Originally Posted by scottewalker View Post
Pie,
Actually, I think it's easiest to start with the corner panel that is right behind the seat first. Remove the weather stripping a bit so you can see how it connects. You'll need to loosen up the panel below it, but not take it out. The corner panel connects to the pillar, so you have to take this one out first.
Then you can take the pillar cover out. You pull up and toward the door.
Old 09-04-2009, 07:26 PM   #8 (permalink)
View ecnal's Photo Gallery
Whenever I pull out plastic that has an airbag behind it, I ALWAYS disconnect the battery. You don't want that launching in your face, as small as the chances are that it would. Just go carefully and gently.
ecnal is offline   Reply With Quote
Old 09-04-2009, 11:52 PM   #9 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
when you disconnect the battery, does it affect the radio presets or the readouts on the instrument panel?
joeylgarcia is offline   Reply With Quote
Old 09-05-2009, 02:28 AM   #10 (permalink)
Gameroom cash: $164100
View lilaznviper's Photo Gallery
i think removing the battery will reset the clock and radio settings
lilaznviper is offline   Reply With Quote
