I removed the emmisions screen from the airbox todahy and saw a noticable inprovement in drivability. I have a 5 speed and always noticed a stumble starting out in first gear unless I slipped the clutch a bit. The stumble is now gone, and almost no jerkiness at all shifting into the other gears as well. I don't know what the mod would do for those with automatics, but it sure made my stick more drivable. There is also a very slight increase in intake noise which sounds nice but still dead quiet at cruise which I also like.
It also feels a but snappier, but I would expect that by getting rid of the restriction and smoothing out the flow.
i'm not into changing the intake, but a few little things here and there are always nice.
No pics needed. Unclip the cover, flip it over you'll see the screen. Pry it out with a flat blade screwdriver and you're done. Takes about 2 minutes. Doubt if you can save the screen 'cause the 6 tabs are melted on.
I removed everything in front of the airbox and removed the emisions filter in the airbox. It has more of a sports car sound when accelerating and is definitely smoother. No noticable loss in torque and it's a little better high end. Drivability is also improved.
Taking in "hot" engine bay air doesn't bother me. It's no different in temperature there then where the stock inlet winds up so no improvement or loss there, but taking 3 ft of plumbing and the carpeted flex tube out of there definitely makes for a straighter path.
I would say that with the TRD filter I have on order, it will probably work just as well as the weapon intake, only be a hell of a lot cheaper.
I didn't want to go low with the plumbing like some of you guys did because I didn't want to turn my motor into a wet vac.
Good stuff, I did the unclip the airbox and was amazed to find that screen. Now I know the purpose, it is useful but sucking out power for sure. Did some little testing of my own and it is definitely something worth looking for when you want better engine response. But I am no mechanic.
hey todayI removed the screen and the plumbing before the airbox. I didn't cut the flex tube so I just removed the whole plastic piece that comes out of the airbox too. I noticed that the plastic piece had a third hole in it right before the flex tube part. I was wondering if anyone could tell me what that was for.
Thanks
Yeah, that "hole" goes into the plastic resonator box that sits in the fender well. Not important for this mod.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
i just took the screen out today, and i was wondering if doing this could allow dirt and other debris into the engine? thanks
No...
As long as you still have your regular air filter you are fine. The Emissions filter is there to prevent CO2 from escaping your engine through the intake system (or something like that). It is redundant protection to make the Toyota Cars "Super Green".
Now if you took both Filters out, both Intake & Emission screen, then yes dirt would get in.
had my air box screen removed for quite awhile now... never noticed any difference what so ever... i suspect its more of a wishful thinking improvement
__________________ 2001 Toyota Tundra TRD 1994 Jeep YJ - no top, no doors May-Oct 1996 Toyota Tacoma - RIP! frame recall $16,638 2009 Toyota Corolla XRS - SOLD
what does the resonator box do exactly? i thought that was the suction line for the charcoal filter. Guess i was wrong
think of the resonator box as an intake muffler. no throaty growl from your intake (or a reduced one at least) It is just one extra place for the air to spool in
It is wishful thinking unless you add a high flow air filter, at which point removing the screen will make a difference.
