Originally Posted by nate89
...I just need to get the front ones on now but I don't have the right sized socket for the lower two bolts holding on the strut. 3/4 is the biggest I have and it's bigger than that so... anyone know what size socket I should run to the store and buy so I can finish?
In general, Toyota uses metric sized nuts and bolts. So your SAE socket set is not going to give you a good fit even if you had a large enough socket. If you can, go to Sears and buy yourself a good Craftsman socket set. They have a lifetime warranty and you will more than likely use them many, many times over your life time. There are other good brands with the lifetime warranty too. I like Sears because they will replace worn or broken Craftsman tools without any hassle.
