Originally Posted by familycar
hey guys need help i was backing up this morning and i ran into a curb by accident. the brunt of the impact was directly on the exhaust tip of the muffler, it got kinda closed up a bit and it made a growl while i drove. i straightened it out right away. the growl is still there thought and there is a bit of a smokey odour coming from under the car. my guess is that i bent up the alignment of the the whole exhaust piping or whatever you call it. what do you guys think it is and is there any danger of the motor siezing up if i drive it to the shop in the morning. the exhaust note sound like theres a performance exhaust in its place. there is also a noticable loss of power from the engine now. can you guys give some ideas on this.
If the shop is close you should be fine. I drove my jeep for 20 miles with a collapsed converter (the jeep would barely move) and it was OK. Just remember, the O2 sensor will compensate to some extent if there is any problem.
Did you check the pipe joint right in front of the rear axle? It's a spring loaded joint and it has room to pop out. If you bent the muffler hangers it might stay out of whack.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
