Originally Posted by cabur
Not sure if keyhole will give you the view of the back on your screen.
I have backup sensors in my LE which gives audio and visual signals within 5'.
Didn'tlike the camera. Hard to see, placement of screen and my head will be looking back when I'm reversing.
I wouldn't put it where the key hole is for a couple of reasons. first, why remove the key lock? that doesn't make sense. Especially since you can use that to lock your truck when using the valet key (look in the manual).
Secondly, it's always going to be filthy back there, especially in winter. plus, mounting it in there would be a bitch and you'd have to put a small window in there for the camera and seal everything up.
If you have a Corolla with a spoiler, I'd recommend this. Put it inside where the third brake light used to be on the rear deck. Way easier to mount, and it's protected by the rear window. But I still wouldn't waste my time. If you're a gadget guy, I'm sure you can think of a lot better things to do to it.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
