TRD Lowered - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2009, 02:11 PM   #1 (permalink)
johncal's Avatar
View johncal's Photo Gallery
TRD Lowered
Just got done lowering the car yesterday. The TRD springs give it a nice level drop. Handling is great, especially with the upgraded wheels and tires and TRD anti sway bar. The car basically goes as fast through the corners as you want it to.
The stability is much better and not much difference in ride quality from stock. Still smooth enough definitely firmer, but not objectionably. I definitely am happy with the results.
The VSC has a higher threshold than before, where it seems to come in a lot less and only when really needed. For this reason I doubt if I will get it recalibrated. Alignment seems good also, so I'll give it a couple of weeks before deciding if I need to get it realigned.
The job took 4 1/4 hrs, start to finish. I used an impact driver for the spring compressors which definitely made the job much easier.
Tomorrow, when I put all of the tools away, I will post a tool list for others that are contemplating lowering their Corolla's. I know I wish I would have had a tool list before I started. I did gather everything before I started, and had everything I needed, which was great, but it would have been nice to have a list of tools, sockets, etc already.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 07-26-2009, 02:18 PM   #2 (permalink)
yuuup!
Gameroom cash: $147260
View Cizzyfunk's Photo Gallery
Looks good!!
I would recommend getting an alignment even though it may seem like you don't need one...it may cause unnecessary wear on your tires...
Cizzyfunk is offline   Reply With Quote
Old 07-26-2009, 02:24 PM   #3 (permalink)
View bydotte's Photo Gallery
nice job.
+1 on the alignment. remember, your wheel hub was basically hanging free while you were changing the spring. i thought my alignment felt fine too, but when i took it in to have it done the fronts were off the chart. let it settle for a day or two then you should bring it in.
bydotte is offline   Reply With Quote
Old 07-26-2009, 04:47 PM   #4 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
An alignment is not optional, in my opinion. Even if you correctly marked the struts with where the camber was set previously, it still needs to be done to make sure.
Most people forget to mark where the camber was before removing the springs, if you didn't forget, good work, however the camber will still be set to where it was for the old springs. That's if you managed to get it perfectly where it was previously, which you probably didn't get it exact. Chances are you are also slightly toed in as well now.
For the sake of tire life and handling, get an alignment.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-26-2009, 05:37 PM   #5 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
You need to get it aligned immediately.
OkSlim is offline   Reply With Quote
Old 07-26-2009, 07:22 PM   #6 (permalink)
johncal's Avatar
Jeff
I'm going to probably get it checked in the next few days, but I set the camber by pushing the struts all the way in for a "more performance setting" as per the TRD instructions. So I'll be discussing that with the alignment people when I get it done. I would agree with the slighly toed in since the lower A arms are now flat vs slightly bent down. Since the toe in setting is adjusted in the rear of the arms, that would make sense that it would come in a tiny bit.
Old 07-26-2009, 07:57 PM   #7 (permalink)
Old Fart
mmasse's Avatar
Gameroom cash: $261903
View mmasse's Photo Gallery
Car is definitely looking good! Something I noticed after my drop is the stock shocks are a little bouncy. Did this happen with you?
mmasse is offline   Reply With Quote
Old 07-26-2009, 09:05 PM   #8 (permalink)
on full afterburner
Gameroom cash: $1346897
looks nice!
Old 07-26-2009, 09:11 PM   #9 (permalink)
johncal's Avatar
No, they're perfect.
Old 07-26-2009, 09:35 PM   #10 (permalink)
View Drachenv6's Photo Gallery
nice wheels! Have you considered tint?
Drachenv6 is offline   Reply With Quote
Old 07-26-2009, 09:37 PM   #11 (permalink)
yuuup!
I think he did get tint according to his sig...
It's there somewhere lol.
Old 07-26-2009, 10:14 PM   #12 (permalink)
View Svrajam's Photo Gallery
Need better, larger pics. Those angles don't show the wheel gap that well.
Svrajam is offline   Reply With Quote
Old 07-26-2009, 10:22 PM   #13 (permalink)
View wchin's Photo Gallery
Would you mind posting a picture or two taken directly from the side? I can't tell how level the TRD springs make the car look from the original pictures. It actually looks like the rear is higher than the front.
Also, did the drop match what TRD says it would drop?
Thanks.
wchin is offline   Reply With Quote
Old 07-26-2009, 11:31 PM   #14 (permalink)
johncal's Avatar
Thanks.
Lowered exactly how TRD said it would. Car is dead level. I'll take additional pics when I get a chance.
Old 07-26-2009, 11:32 PM   #15 (permalink)
johncal's Avatar
Tinted with 30% Lumar tint
