Panel Removal??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2009, 01:39 AM   #1 (permalink)
madhatter's Avatar
View madhatter's Photo Gallery
Panel Removal???
I am blacking out my interior and need to know if I can safely remove the front pillars without setting off the airbags, would unplugging the battery work? Thanks.
madhatter is offline   Reply With Quote
Old 08-23-2009, 12:02 PM   #2 (permalink)
Corolla Driver
Schroeder64's Avatar
View Schroeder64's Photo Gallery
how are you going to black it out? plastic spray paint?
http://www.cardomain.com/ride/3875710
CLICK for my CarDomain^^
Schroeder64 is offline   Reply With Quote
Old 08-23-2009, 11:34 PM   #3 (permalink)
madhatter's Avatar
Yes, it is called Krylon, it is a satin black and I have done most of the the dash already and I am not complaining anytime soon, It doesnt chip and it looks very clean. All I really need to do now is remove the front pillar casing to paint them, too much patience for me to get tap and newspaper in all of the nook and crannies!!!
Old 08-24-2009, 12:09 AM   #4 (permalink)
View CanadianXRS's Photo Gallery
Whenever doing work with an airbag or anywhere near it, disconnect the negative from your battery.
CanadianXRS is offline   Reply With Quote
Old 08-24-2009, 02:20 AM   #5 (permalink)
View trunks9_us's Photo Gallery
you know I hate being a ass but why not use the search feature? I have showed this many times
2009 Corolla S Enkei Rims
Sundown 1500d
2 Jbl Gti's
Kinetik hc1800.
Big 3 with pics tutorial soon
trunks9_us is offline   Reply With Quote
Old 08-24-2009, 02:20 AM   #6 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
You can disconnect it if you'd like, but you shouldn't even really be touching the airbag. The cover is in no way attached to the airbag itself.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 08-24-2009, 07:51 AM   #7 (permalink)
View ericgu22's Photo Gallery
would definitely want to see the result of the black out!!!
ericgu22 is offline   Reply With Quote
Old 08-24-2009, 11:14 AM   #8 (permalink)
Old Fart
mmasse's Avatar
Gameroom cash: $261903
View mmasse's Photo Gallery
+1 for Krylon they make a plastic only spray called Fusion that after a 7 day cure will not chip. I have use this for those annoying silver accents on the side of the radio/enviro controls without issue.
mmasse is offline   Reply With Quote
Old 08-24-2009, 01:02 PM   #9 (permalink)
johncal's Avatar
View johncal's Photo Gallery
What ever paint you use, you might want to consider using a mat clear coat or mat finish. A glossy finish will be very aggravating when the sun comes in.
You might want to base coat black with the Fusion, but use a different brand mat clear when the base coat is cured.
Most Hobby and Joanne Fabric, etc sell mat finish clears that are very good. Just test FIRST on a scrap piece of material to be sure the clear won't lift or curdle the base coat.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 08-24-2009, 03:15 PM   #10 (permalink)
Old Fart
mmasse's Avatar
I used in this particular application a Flat black. Which is working out really well. Its just a tedious process with all the wet sanding
Old 08-24-2009, 03:56 PM   #11 (permalink)
johncal's Avatar
The only negative to flat black is that gets marks on it very easily. Other than that though.......
Old 08-24-2009, 06:54 PM   #12 (permalink)
madhatter's Avatar
will do.
Old 08-24-2009, 06:55 PM   #13 (permalink)
madhatter's Avatar
Jeff
I was unsure if I had to be careful pulling it off. I didnt want to trigger anything. Thank you.
Old 08-24-2009, 08:48 PM   #14 (permalink)
madhatter's Avatar
Here ya go, didnt have to time to clean the car so kinda messy and the paint is all but done I just need to do something with the carpet and seats.
Old 08-24-2009, 10:16 PM   #15 (permalink)
View Svrajam's Photo Gallery
I'm sorry, but that looks absolutely awful. I'm not going to say anything else, as that will only be mean. But... yikes.
Svrajam is offline   Reply With Quote
