Low Coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2009, 08:52 PM   #1 (permalink)
View ericgu22's Photo Gallery
Low Coolant
Checked the Coolant level and its was little below low, Should I be Concerned?? My Corolla has 30000km and Should I top it up myself or take it to the dealer??
ericgu22 is offline   Reply With Quote
Old 08-30-2009, 08:59 PM   #2 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $520919
View LeanBurn's Photo Gallery
Canada
Odd. It shouldn't be losing coolant at this low of distance on the odo.
I would actually take it in, get it registered that something unsual is taking place in their books.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 08-30-2009, 09:09 PM   #3 (permalink)
View CJCride's Photo Gallery
Canada
Never open the Radiator Cap on a warm engine. When it is cold remove the cap it should full to the top. Add some straight [not mixed] coolant to the overflow bottle to bring it up to the middle of the two lines. Best to do this on a cold engine.
Sounds like you are new to this stuff the best thing you can do is to get the Haynes or Chiltons manual or both and check out the wealth of info on your car.
CJCride is offline   Reply With Quote
Old 08-30-2009, 09:11 PM   #4 (permalink)
The car has 30000km ,could it be a leak?? The low coolant light haven't come on yet!!
Old 08-30-2009, 09:32 PM   #5 (permalink)
What year and model is it?
Old 08-30-2009, 09:42 PM   #6 (permalink)
2009 Corolla S
Old 08-30-2009, 09:48 PM   #7 (permalink)
Canada
2009 Corolla S
Check w/dealer get a work order to keep. It's probably nothing more than a top up but just in case keep the paper work.
Old 08-31-2009, 06:38 PM   #8 (permalink)
View pwain's Photo Gallery
This is a 09 Toyota, not a 95 Ford. I don't think you will be finding a 3rd party service manual for quite some time.
pwain is offline   Reply With Quote
Old 08-31-2009, 08:14 PM   #9 (permalink)
Dragon877's Avatar
View Dragon877's Photo Gallery
I would play it safe and take it to the dealer and ask them to check just to be sure
Dragon877 is offline   Reply With Quote
Old 08-31-2009, 08:37 PM   #10 (permalink)
Agreed, I assumed it was an older model, frankly I was surprised to see 2009.
Old 09-03-2009, 11:07 PM   #11 (permalink)
check the coolant today again and was little over low!! The coolant suddenly came back, anyone what happened?? Is it just stuck in the hose or what??
Old 09-04-2009, 12:19 AM   #12 (permalink)
View jkowalski's Photo Gallery
First, did you check the engine coolant both times with the engine at the same temperature (either fully cold both times, or fully warmed up both times).
Second, how far below the "FULL" line is the coolant? My coolant is probably, maybe, half an inch (give or take) below the "FULL" line when the engine is cold. After my drive home (about 13 miles from work), it's about up to the "FULL" line.
Coolant, like any other fluid, expands as it heats up, and contracts as it gets colder. (We have this problem all the time at work with hydraulic fluid)
Basically, check your coolant at the same engine temperature (fully cold or fully warm) but as long as it's between the "ADD" (or "LOW" or whatever the container says) and "FULL," and it reads the same level when you check it, you really don't have any problems.
2009 Corolla S, 5 speed manual, power moonroof, "sport package," VSC.
jkowalski is offline   Reply With Quote
