Your supposed to check the fluid hot (after driving a while), while the car is on level ground, the only difference from what svrajam said is you are supposed to check it with the engine idling, in park. Yes, you are supposed to check it with the engine ON.
(I clarify park because first, thats what the manual says, and second, because on Chrysler transmissions, you check in neutral because the transmission doesn't pump fluid in park)
2009 Corolla S, 5 speed manual, power moonroof, "sport package," VSC.
