Originally Posted by Exor
Hey everyone:
Wondering if anyone knows which method Toyota wired the reverse lights in the 2010 Corolla.
Positive-side or Negative(Ground)-side switched...
Thanks in advanced.
Cheers,
John
I can tell you this. The headlights are negative switching as are most things that are controlled by an ECU. easy enoght to tell. Just put a volt meter on the positive side of the reverse light to ground when the light is off. If you have voltage then it is negative switching. (Also, you'd get no continuity to ground).
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
