Rear Seatback Support Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2009, 11:50 AM   #1 (permalink)
View Exit9's Photo Gallery
I am installing an amp in an 09 Corolla on the back of an rear seats. I was just going to mount it directly with the supplied mounting screws. Is the seat back metal or plastic under the carpet? If metal do I need to put a board in between for amp isolation to prevent electrical noise?
Exit9 is offline   Reply With Quote
Old 10-07-2009, 12:16 PM   #2 (permalink)
View iMPER_'s Photo Gallery
It is a metal structure under the carpet. I mounted my amp to it using self-tapping screws...the main issue I ran into was that the metal is not flat - so it took some time to figure out where to land my screws considering the hole pattern I was working with. In the end, you should be able to do it, but it can be difficult to drive your screws where you want them and also keep your amp straight.
iMPER_ is offline   Reply With Quote
Old 10-07-2009, 05:14 PM   #3 (permalink)
Thanks. Did you have any ground loop issues or is the seatback isolated from the chassis?
Old 10-07-2009, 07:39 PM   #4 (permalink)
2010 Corolla S
Gameroom cash: $230908
View TFCommanderBob's Photo Gallery
I could be wrong, but the material your amp's mounting brackets are screwed into should have no affect on your ground, and just being near metal isn't necessarily bad (think computer case).
Just be sure to pick a solid grounding point for your ground wire!
TFCommanderBob is offline   Reply With Quote
