XRS clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2009, 04:05 PM   #1 (permalink)
kniterider09's Avatar
Gameroom cash: $289977
View kniterider09's Photo Gallery
Exclamation XRS clutch
so i went to the dealer to get my car checked due to the occasional engine issue, apparently all seems to be fine, and my car seems to be working fine as well, so not sure what had happened few days back.
anyway, the tech found out that my clutch pedal needed readjustment. the tech said, that I had played around with my clutch pedal causing it to reposition. in other words, it was higher than it shud be. now i personally didnt do anything to that pedal, its been the way it is since i picked up the car brand new from the dealership. they said clutch repairs are not covered under warranty so they'd charge me $60 for readjusting, and the tech said it'll take him 15 mins. i told him to go ahead cause he said its causing an issue with my clutch engagement/disengagement. it took the guy nearly an hour to correct it to "factory" settings, they ended up charging me $50 for their error. no worries there.
when i actually sat in my car to drive back home, i could not believe how much of a difference that adjustment had made . it was almost like i had to learn the engagement point again. honestly, it feels 10X better than how it was previously, the clutch pedal travel is significantly shorter now and its very smooth to operate the clutch and gearbox.
this makes me wonder how many other xrs 5spd owners are driving their cars who could also have the same issue and not know about it. i suggest check your clutch pedal height, it should be same level as your brake pedal if not even lower.
just thought i'd put it out there in case anyone else ever wondered why is their clutch pedal travel distance so long. again, it might have just been my car.
kniterider09 is offline   Reply With Quote
Old 10-06-2009, 10:37 PM   #2 (permalink)
yuuup!
Gameroom cash: $147260
View Cizzyfunk's Photo Gallery
When I got the car I asked about the clutch positioning because it was higher than the brake and gas pedal and they said that was normal...UGH!
Cizzyfunk is offline   Reply With Quote
Old 10-06-2009, 10:43 PM   #3 (permalink)
i dont know what's normal anymore. read my other thread. now i am stuck with a bigger issue. i shud demand my money back from them for messing it up.
Old 10-06-2009, 11:45 PM   #4 (permalink)
Megan Exhaust
RollaRed's Avatar
Gameroom cash: $222190
View RollaRed's Photo Gallery
Wow i didn't know this. But my clutch pedal is also higher than my brake pedal. It's been like that since i bought it. But i have the 1.8l engine. Can anyone else with a 5sp 1.8l corolla tell me if there clutch pedal is higher than there break pedal?
RollaRed is offline   Reply With Quote
Old 10-06-2009, 11:57 PM   #5 (permalink)
Damnit Man's Avatar
View Damnit Man's Photo Gallery
Must be normal, I just checked my 2010 S clutch and it is above the brake pedal.
Damnit Man is offline   Reply With Quote
Old 10-07-2009, 12:57 AM   #6 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
The clutch pedal sits quite a bit higher than the brake pedal in all 10th Gen Corollas. It's the normal positioning.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 10-07-2009, 01:00 AM   #7 (permalink)
Jeff
so the tech messed it up cause now mine sits below the brake pedal. and cost me 55 bucks.
Old 10-08-2009, 01:10 PM   #8 (permalink)
Megan Exhaust
RollaRed's Avatar
Yeah because i've never had a problem with the clutch and i already have 20k miles on my car.
Old 10-08-2009, 01:53 PM   #9 (permalink)
its back to the way it was now, higher than the brake pedal.
