I just changed mine on my Matrix and at first had the same trouble.If they're the same, there is a little tab that flips open allowing the wiper arm 'hook' to slide through the blade so you can get it off.
the Tab that flips out is not on the inside of the hook (like replacement blades) but it's facing you as you look at the blades
HTH
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
