Need help removing connector - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2009, 05:03 PM   #1 (permalink)
View Exit9's Photo Gallery
I got the right door panel off ok but I can't figure out how to get the driver's door electrical connector out of its socket. I know there is a release somewhere but I can't find it. A detailed description would help a lot. Thanks.
Exit9 is offline   Reply With Quote
Old 10-30-2009, 07:07 PM   #2 (permalink)
Gameroom cash: $157000
View pinoyesv6's Photo Gallery
its been almost a week since i've had that door panel off. if i recall, you have to pull on it to release it.
pinoyesv6 is offline   Reply With Quote
Old 10-31-2009, 09:29 AM   #3 (permalink)
I finally got the driver’s door panel electrical connector out.
I used a water-pump-pliers to grasp both ends of the electrical plug and pulled it out about a quarter of an inch. On the side of the socket there is a slot with a connector plug tab sticking out. Pulling the connector out a quarter of an inch pulls the connector tab to the top of the slot. Using a flat tip screwdriver, depress the tab ridge so it goes under the socket connector and pull the electrical plug out.
Hope this helps someone else out.
