First thing I have to say is make sure you read the owners manual and understand it. If you don't, talk to your service advisor about what you want clarified.
Originally Posted by corollasportvsc09
I just brought my car in for an old change and tire rotation to the dealer. They told me to replace the cabin air filter. I was surprised because the manual said every 3 years or 36,000 miles. I didn't let them do this service. It looks pretty easy to replace myself looking at the manual. Where should I order one from or should I wait two more years?
A cabin filter is essentially like the furnace filter in your house, it keeps the air going out of your vents clean of pollen and dust. If its dirty replace it otherwise it will continue to catch what it can till it plugs up completely and reduces air flow to almost nothing. I can't recall what the manual stated for time however I know in Canada recommended replacement intervals are about 30,000 KM. You can purchase one through Toyota. I'm not sure which aftermarket companies make them so I can't comment on them.
They also did a recall fix on the brakes, something about them not working that great in cold weather. Lastly, they said they adjusted my rear brakes. I was surprised that I needed my rear brakes adjusted after 12,000 miles, but they said this was done under the warranty and didn't charge me. Is this something I will need to do each year? What other brake services will be needed?
No having your brakes adjusted is not necessary each year. If it was necessary that means the technician working on it noticed something that needed to be corrected, quality service. Other brake services that will be needed are just basic maintence, such as replacing pads, rotors, shoes and drums as necessary.
I was reading the manual and it said to get the drive shaft bolt tightened at 15k miles. What is this and what should this service cost?
Since you drive a Corolla that service doesn't affect you.
When does the brake fluid need to be changed since it isn't stated in the manual?
Your brake fluid will likely never need to be changed, however having it done isn't going to hurt anything if done properly. Personally if I was going to do it, 100,000 KM would be about the time.
When does the coolant need to be flushed and/or changed?
Needs to be done at 160,000 KM or 100,000 Miles.
When does the transmission fluid need to be flushed and/or changed?
Changed at 96,000 KM
