TRD Parts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2009, 10:39 AM   #1 (permalink)
View MrMoose's Photo Gallery
TRD Parts
Does anyone have experience with the TRD quickshifter? I know it won't void the warranty (I have the extended 6 year). Does is reduce height at all?
I've seen the TWM one and it looks like it works great, my only worry is installation (I do not have the time at all) and warranty. I know for sure the TRD won't void the warranty. I paid for the extended 6 year warranty, I don't want to mess that up.
Also I am looking to do the TRD rear sway bar at the same time. Possibly front strut brace as well? Any tips would be excellent. (TRD springs and TRD 18" silver 5 spokes in the spring!)
MrMoose is offline   Reply With Quote
Old 11-14-2009, 10:57 AM   #2 (permalink)
johncal's Avatar
View johncal's Photo Gallery
Some guy with the XRS models have had some issues with it. do a search. There is a better one out there that guys have been buying that does have a shorter lever. The TRD one doesn't change the stock lever height.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 11-14-2009, 11:18 AM   #3 (permalink)
Serge's Avatar
View Serge's Photo Gallery
TWM is the way to go
Serge is offline   Reply With Quote
Old 11-14-2009, 01:27 PM   #4 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
The TRD short shifter gets mounted on the transmission side of the cables, as such the interior of the car isn't even touched when it gets installed.
I have had zero issues with mine.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 11-14-2009, 09:44 PM   #5 (permalink)
The Corolla That Could
shotgunjimmy's Avatar
Gameroom cash: $213000
View shotgunjimmy's Photo Gallery
did you notice a diference with it installed?
shotgunjimmy is offline   Reply With Quote
Old 11-15-2009, 04:16 AM   #6 (permalink)
Jeff Lange's Avatar
Yes, the throw is quite a bit shorter.
Jeff
Old 11-15-2009, 04:10 PM   #7 (permalink)
dj2000lbs's Avatar
View dj2000lbs's Photo Gallery
I have the TRD one and its ok you get use to it after a while mine dosent give me any problems but if I could do it all over again I would have got the TWM. The TRD dosent lower the shifter height and its a pretty big difference over stock but its not like WOW this is a short throw. I've had it since October and I've even thought about buying the TWM now cause i'm not really satisfied with it...
dj2000lbs is offline   Reply With Quote
Old 11-15-2009, 05:34 PM   #8 (permalink)
the TRD one would be perfect for me. I dont want a shortened heighth, i just want the throws to be shorter. if you end up getting the TWM one, let me know and if i havent got it already, ill buy your TRD shifter.
Old 11-15-2009, 11:57 PM   #9 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1341666
iTrader Score: 7 reviews
Does anyone know if there is a short shift kit for the 1.8?
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 11-16-2009, 07:24 AM   #10 (permalink)
Pretty sure the TWM works as well since it is the same trans setup. The TRD works with both, so I don't see why TWM wouldn't.
Old 11-16-2009, 11:55 AM   #11 (permalink)
Jeff Lange's Avatar
No, the TRD one only works on the 2.4L, and the transmission setup is NOT the same between the two.
That being said, I believe the TWM replaces parts inside the car, instead of at the transmission end (like older TRD quickshifters used to), so it will probably work with both the 1.8L and 2.4L, but don't take my word for it. I'd ask TWM before ordering, or get confirmation from someone here on the boards before you decide to go for it.
Jeff
Old 11-16-2009, 12:52 PM   #12 (permalink)
johncal's Avatar
Everything you wanted to know.
TWM performance SS and Bushings
Old 11-16-2009, 07:20 PM   #13 (permalink)
Diehard Rams Fan
Thanks!
