Has this happened to anyone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 06:52 AM   #1 (permalink)
View Silver09's Photo Gallery
Has anyone had a high pitched noise come from their car when the car wasn't even started?
This is what happened with my car the other day.
I unlocked my car using the key in the door handle method. Turned the key back twice because I would be opening the back driver side door first.
I opened the door, started to put some stuff in the back seat when I heard this high pitched sound.
looked around to find out where the noise was coming from or what was causing it.
It was then I realized the noise was coming from my car.
The best way I can describe what the noise sounded like is that it sounded a lot like the noise the car makes when you use the remote trunk opener on the fey fob.
The noise however was constant and it only stopped after I shut the same door.
I pretty sure that I wasn't accidently pressing any of the buttons on my key fob when this was happening and I know I wasn't, when I shut the car door.
The trunk was not open either.
If I was in an area where this noise wouldn't have been annoying to people, I would've waited to see if it stopped on its on or if it would've kept going until I shut the door.
As it was, it went for about 10 seconds before I realized it was coming from my car and then shut the door.
I unlocked and opened the same door again like I did the first time to see if the same thing would happen but, it didn't.
Does anyone have an explanation as to what might have caused this?
I've had the car for over a year and this is the first time this has ever happened.
It's the Sport model.
Silver09 is offline   Reply With Quote
Old 11-16-2009, 07:06 AM   #2 (permalink)
The random one
Gameroom cash: $121516
View MiniPacou's Photo Gallery
you accidently pressed the lock button on the remote? It warn you if you try to lock a door and theres one not closed properly... it beeps constantly until that door is closed.
MiniPacou is offline   Reply With Quote
Old 11-16-2009, 07:08 AM   #3 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
Was it the gas tank depressurizing?
OkSlim is offline   Reply With Quote
Old 11-16-2009, 07:20 AM   #4 (permalink)
View MrMoose's Photo Gallery
The car beeps something fierce when you have the door open and try to lock it with the key. It's normal, just close all of the doors then hit the lock button.
MrMoose is offline   Reply With Quote
Old 11-16-2009, 09:57 AM   #5 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
I think I read somewhere in the manual for my Matrix that you might hear the fuel pump or something when the car is off, so maybe it just the fuel pump priming.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 11-16-2009, 12:38 PM   #6 (permalink)
Gameroom cash: $457387
View cabur's Photo Gallery
I have this notice of noise attached to my gear knob when I take delivery of my car. 1.8 LE (Canadian)
"Approximately five hours after the engine is turned off, you may hear an electric motor sound coming under the luggage compartment for several minutes.
It's not a malfunction.
It is the sound of a pump performing a fuel evaporation leakage check.
See Owner's Manual for details"
cabur is offline   Reply With Quote
Old 11-16-2009, 12:47 PM   #7 (permalink)
johncal's Avatar
View johncal's Photo Gallery
It's the lock thing like they said. It was a bit confusing the first time it happened to me as well.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 11-16-2009, 04:08 PM   #8 (permalink)
View steve376's Photo Gallery
USA
I just went out to my car and tried to lock it with a door open, very interesting sound. At least now I know what it is if I hear it again.
steve376 is offline   Reply With Quote
Old 11-16-2009, 05:20 PM   #9 (permalink)
msncorolla422's Avatar
Gameroom cash: $460745
View msncorolla422's Photo Gallery
yeah this is what most newer model toyota's that have the keyless entry system do if you have any of the doors open and hit the lock button. i guess it's just a warning so that maybe you dont leave your keys in the car or something. just like if you have the key turned to the on/acc position, and you hit the lock button on the door. it will lock and then unlock all the doors
msncorolla422 is offline   Reply With Quote
Old 11-16-2009, 05:54 PM   #10 (permalink)
The Corolla That Could
shotgunjimmy's Avatar
Gameroom cash: $213000
View shotgunjimmy's Photo Gallery
instead of shutting the door, when this happens you can just press the unlock button on the key fob and it will make the noise stop.
shotgunjimmy is offline   Reply With Quote
Old 11-16-2009, 06:55 PM   #11 (permalink)
Tried what some of you suggested was the cause and, that's what it was. Thanks.
Kind of an odd feature though.
If it's meant to be a kind of an alert, was doesn't it do the same thing when you manually lock all the doors using the inside driver side door lock, while a door is left open?
While I'm at it,☺, why doesn't the driver side window automatically go up with one touch of the window up/down button?
My sister in law's vehicle(non Toyota) has that ability.
Seems like an incomplete option on the Toyota.
Old 11-16-2009, 08:53 PM   #12 (permalink)
USA
I don't like how it doesn't have a auto up feature on the driver side window too. I learned how to drive a 1 1/2 years ago on my mom's 4runner and I got use to the auto up/down and it really bothered me when I got my corolla back in march. I really like my sisters jetta, because all the windows have auto up/down and can stop the auto by push/pulling it again which I think is easier than what toyota does. and you can control all the windows up/down using your key on the drivers door
