Noticable power loss 1.8L - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2009, 11:12 PM   #1 (permalink)
RussianBadBoyLB's Avatar
View RussianBadBoyLB's Photo Gallery
Since I adjusted my rear drum brakes, its as if my car has gotten slower. When I accelerate, usually I can hear the intake pretty well, now its more dim. Then It also feels as if something is dragging it, it just feels different. This might be due to adjusting the rear drums. I did spin the tire after adjusting, and it made one revolution. Could it be too tight?
RussianBadBoyLB is offline   Reply With Quote
Old 12-01-2009, 12:00 AM   #2 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
I'm no rocket scientist but I am gonna have to go with,
You tightened the drums too tight and they are dragging
OkSlim is offline   Reply With Quote
Old 12-01-2009, 12:13 AM   #3 (permalink)
View 2010rollaS's Photo Gallery
Thats all I can think of too. Why did you adjust the drums anyways?
2010rollaS is offline   Reply With Quote
Old 12-01-2009, 04:58 AM   #4 (permalink)
Cause you have to adjust them as they wear out. Not doing so will wear out your front pads very quickly. Front brakes are used 80% and rear drums 20%, that's in stopping power that is. So when not adjusting your rear brakes, the 20% would be more like 15% or 10%. I might of adjusted them too tight. I mean how tight should the parking brake be?
Old 12-01-2009, 07:41 AM   #5 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521119
View LeanBurn's Photo Gallery
Canada
I am sure that modern day drum brakes are self adjusting after initial install. I have never adjusted mine except after replacing for 35 years or so on imports or domestics, and my front disks have never seen accelerated wear...but hey, that's just me.....
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 12-01-2009, 07:59 AM   #6 (permalink)
View trucknut1's Photo Gallery
all modern cars (past 20+ years) have self adjusting rear drums,when equiped with rear drums that is, adjusting is rarely necessary... i have only had to adjust on older vehicles where the adjuster has seized... jack up the rear end and see if your wheel is "free wheeling" if it isn't slack it off a tad, you dont want to cook your rear shoes or overheat your rear pistons... plus its hard on your transmission if the brakes are dragging
2001 Toyota Tundra TRD
1994 Jeep YJ - no top, no doors May-Oct
1996 Toyota Tacoma - RIP! frame recall $16,638
2009 Toyota Corolla XRS - SOLD
trucknut1 is offline   Reply With Quote
Old 12-01-2009, 08:05 AM   #7 (permalink)
The random one
Gameroom cash: $121516
View MiniPacou's Photo Gallery
yeah, like some other posters said, they're usually self adjusting. To get them adjusted properly find out how they auto-adjust. In some cases they adjust when you press on brakes and theres a lever adjusting up the screw, or by the hand brake, or when you back up and slam the brakes. Adjust it loose and try it up in ur driveway, you'll see if they self adjust, if they do, you never need to touch em. You just gotta be careful they dont rust and seize if you're where theres severe winterstorms+salt.
have somebody pressing the brakes while you observe the mechanism...
OR, do the all question's solution: GO TO THE DEALER, haha
MiniPacou is offline   Reply With Quote
Old 12-01-2009, 08:18 AM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135623
View Hajoca's Photo Gallery
The drums are self adjusting, but only self adjust in very small increments. (Only while driving and braking in reverse too)
The proper way is adjust the shoes so that they drag on the drum slightly with the parking brake engaged at 2 to 3 clicks. No drag what so ever when the parking brake is released.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 12-01-2009, 09:24 AM   #9 (permalink)
It needsa muffler bearing
Gameroom cash: $127577
View ej063090's Photo Gallery
Rear drum brakes should be cleaned and checked for adjustment regularly and only be adjusted if neccesary. you can adjust the rear drums from the inner part of the drum
2010 Corolla S Black-Auto-Fujita SRI-Debadged -Mobil 0W-20 Oil-Nokya Yellow Fogs-All led swap-TRD FSB-TRD Lowering Springs-DDM 6k HID-Shift boot/CF Shift Knob-20/35 Tints-Tenzo r Cuzco Wheels-SmokeTail Lights
On the way: Borla exhaust-DC Sports Headers
ej063090 is offline   Reply With Quote
Old 12-01-2009, 12:18 PM   #10 (permalink)
Gameroom cash: $199666
View jkg065's Photo Gallery
Drum brake adjustments should be performed with wheel/tire assembly held on with lug nuts snugged on. The same for adjusting with drums only so that the drum is fully seated on the axle hub. Car was loaned out to a "friend" who drove some miles with a soda can stuck between the console and emergency handbrake handle. She partially crushed the can when releasing the handbrake in the down position but the brake was not fully disengaged. Fortunately no warped drums or damaged components!
'04 Nissan Altima 3.5SE
'08 Corolla CE (wife's)
jkg065 is offline   Reply With Quote
Old 12-01-2009, 12:50 PM   #11 (permalink)
johncal's Avatar
View johncal's Photo Gallery
Wow, that's really paying attention.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 12-01-2009, 06:30 PM   #12 (permalink)
so your telling me that the tire should not make one full rotation without the parking brake engaged? Right now the tire makes one full rotation and stops. Before I adjusted them the tire would spin and spin and spin for about 20 rotations. So there should not be any drag, it should keep spinning and spinning? That does not sound right.
Old 12-01-2009, 08:44 PM   #13 (permalink)
OkSlim's Avatar
I don't buy your theory.
When the system is designed to self adjust when you back up
Old 12-02-2009, 03:08 AM   #14 (permalink)
ok I' am a bit confused here. One person tells me its done one way and another person tells me its done another way. Here is what I know from auto mechanics at school. Drums brakes have to be adjusted from time to time, because the pads on them do wear out. Now as far as self adjusting I know for a fact disk brakes are self adjusted due to their construction and design, drums however are not. Can someone please provide some proof of self adjusting drum brakes on a 10th gen Corolla. Backing up does not seam to be the right thing. Why would they have the dial then?
I probably phucked it up by turning the dial. I did not even count how many times I clicked the dial on each one. I just clicked and spun the wheel until it only can spin one revolution. Can someone please explain how many revolution the wheel should spin without the parking brake applied. And how to properly adjust my drum brakes. I don't think backing up is gonna do me any good since I must of adjusted them too tight. Thank you
Old 12-02-2009, 02:44 PM   #15 (permalink)
Darkside Cut Me!!!
If wheel spins one rev then stops = slight drag.
You are trying to achieve No drag when parking brake is OFF.
Once again, the star wheel is turned a slight amount by the lever attached to rear shoe when you apply brakes. Once the rear brake shoe moves enough, the lever will skip a notch on the star wheel and spread the adjuster a tiny bit.
2004 RX330 Sport
2003 Cam I4 XLE
