All 4 signals don't work??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2009, 11:23 AM   #1 (permalink)
View ericgu22's Photo Gallery
So received my Led bulb for the front, installed it and when i put on emergency light, suddenly does not blink and all four signal's are out. What could be the problem??
ericgu22 is offline   Reply With Quote
Old 12-11-2009, 11:38 AM   #2 (permalink)
Dragon877's Avatar
View Dragon877's Photo Gallery
you might have popped a breaker, did you check your circuit breakers?
Dragon877 is offline   Reply With Quote
Old 12-11-2009, 12:12 PM   #3 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521219
View LeanBurn's Photo Gallery
Canada
So you have 1 LED bulb and the rest are OEM incandescant type?
If you put back the normal OEM bulb does it work again?
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 12-11-2009, 02:13 PM   #4 (permalink)
Megan Exhaust
RollaRed's Avatar
Gameroom cash: $222190
View RollaRed's Photo Gallery
if it doesn't work unplug the led bulb and rotate it 180 degrees and put it back in. My rear ones did that....when i pressed on the breaks my lights wouldn't go brighter and then i rotated em 180 degrees and they work just fine.
RollaRed is offline   Reply With Quote
Old 12-11-2009, 05:33 PM   #5 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
^^the polarity problem with +/-
Bay Area Corolla
flamedrgn is offline   Reply With Quote
