flashing maintenance required - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2009, 10:26 AM   #1 (permalink)
View Mosquared's Photo Gallery
Is it normal for the maintenance required light to flash for 30 seconds or so after the car has started? I know that it does flash when you first start the car but I've noticed it flashing for a longer period. It does eventually turn off though. Also, I've noticed that it came on once when i was in reverse.
Mosquared is offline   Reply With Quote
Old 12-22-2009, 10:32 AM   #2 (permalink)
It needsa muffler bearing
Gameroom cash: $127577
View ej063090's Photo Gallery
Your probably close to the 5000 miles after the last time the light was set. Reset it by switching it to trip A, holding the stick in, turn the car off, turn it to accessory mode and you will see bars on the dash fill up and the trip a will zero out. Then let go and your light is off. You might have to have it on odometer instead of trip A.
2010 Corolla S Black-Auto-Fujita SRI-Debadged -Mobil 0W-20 Oil-Nokya Yellow Fogs-All led swap-TRD FSB-TRD Lowering Springs-DDM 6k HID-Shift boot/CF Shift Knob-20/35 Tints-Tenzo r Cuzco Wheels-SmokeTail Lights
On the way: Borla exhaust-DC Sports Headers
ej063090 is offline   Reply With Quote
Old 12-22-2009, 03:23 PM   #3 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
Although he is right, i wouldn't do that unless youve already changed your oil for the past 5000miles. the light flashes about 200miles before you actually need an oil change.
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 12-22-2009, 03:29 PM   #4 (permalink)
Ahh OK that makes sense. I'm about 4700 miles right now. Thanks guys!
Old 01-24-2010, 07:10 PM   #5 (permalink)
TACO_KID's Avatar
Gameroom cash: $435915
View TACO_KID's Photo Gallery
i havent seen it flash before. my 10 xrs light came on at 5k miles. as for reset, you just need to be on trip-A, turn key off, then hold odo stick down (in) and then turn key on (no need to start), hold until light goes out.
TACO_KID is offline   Reply With Quote
Old 01-24-2010, 08:52 PM   #6 (permalink)
flamedrgn's Avatar
it should flash for 5-10secs at startup then go away 200-300miles before oil change and should be solid ever 5000miles.
Bay Area Corolla
Old 01-24-2010, 09:38 PM   #7 (permalink)
TACO_KID's Avatar
hmmm, i never saw the light until my odo hit 5k.
