Stereo Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2010, 03:11 AM   #1 (permalink)
whaambulance's Avatar
View whaambulance's Photo Gallery
Stereo Replacement
Hi all, I just bought the Sosche wiring harness and mounting bracket to replace my headunit, what about the radio? i havent ripped the dash apart yet, but do i need a adaptor for the radio as well? thanks in advance.
http://www.cardomain.com/ride/3819096
2010 Corolla S, Blue Streak Metallic, K&N Drop in, 15% rear tint, 3.5k yellow fogs, pioneer AVH-P4200DVD headunit
whaambulance is offline   Reply With Quote
Old 01-21-2010, 05:49 AM   #2 (permalink)
Toyota Addict
Gameroom cash: $190660
View clintj's Photo Gallery
By mounting bracket you mean the plastic cover that makes the radio fit into the dash with out having a gap correct (actually usually called a dash kit)?
You *should* be able to use the metal mounting bracket on our factory radio on your aftermarket radio.
I haven't installed anything but an eonon unit in 10th gens but I'm pretty sure you should be all set.
clintj is offline   Reply With Quote
Old 01-21-2010, 03:50 PM   #3 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
what you would need is a single din or double din dash kit and wiring harness(unless you do alittle ghetto wiring). you probably have the sosche set already but im not sure because you talk about "mounting brackets" only.
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 01-22-2010, 05:13 AM   #4 (permalink)
im sorry, my vocabulary sucked in my initial post. I got the whole wiring harness and radio install ok, i was refering to the radio antenna, do i need an adaptor for it for an aftermarket headunit? thanks
Old 01-22-2010, 10:41 AM   #5 (permalink)
View sienna1's Photo Gallery
No, it's just a standard plug.
sienna1 is offline   Reply With Quote
The Following User Says Thank You to sienna1 For This Useful Post:
whaambulance (01-22-2010)
Old 01-22-2010, 03:48 PM   #6 (permalink)
View lolitsalan's Photo Gallery
You have your original wires, and then the wiring harness should basically be the "adapter" from your original wires to your new aftermarket radio.
Selling my aftermarket touchscreen head unit. Check it out!
http://www.toyotanation.com/forum/sh....php?p=3640153
lolitsalan is offline   Reply With Quote
