FLASHER in COROLLA - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2010, 01:36 PM   #1 (permalink)
View andrewwoo's Photo Gallery
FLASHER in COROLLA
Hello,
I wanted to know if anyone here knew where the flasher for the corolla is. As posted before on the camry forum, it was behind the instrument panel.
I have checked and the flasher isnt there.
Please let me and everyone know where the flasher is in the corolla.
THANKS!
2009 BLUE Streak Metallic Toyota Corolla S
6000K HID Retrofit TL Projectors| 6000K HID H11 LEDs | Interior White LED Lights | White Cathode Trunk Light
Door Sills | Factory Remote Starter | Ipod Adapter | 15% High Performance Metallic Tint
TRD RSB | UR 19mm RSB | UR LB
andrewwoo is offline   Reply With Quote
Old 01-30-2010, 02:27 PM   #2 (permalink)
CRT > LCD
ZenithTheTV's Avatar
Gameroom cash: $243382
View ZenithTheTV's Photo Gallery
Do you mean the diagnostics port? Or the Hazard Flashers?
Diagnostics port is right below the coin compartment, just above the hood release handle. The hazard flasher button is in the center of the dash, between the air vents.
Sorry if I'm not understanding the question correctly.
edit: Ah I just checked the camry forums, assuming its the flasher relay for the signal lamps. That's beyond me haha, sorry!
ZenithTheTV is offline   Reply With Quote
Old 01-30-2010, 02:50 PM   #3 (permalink)
yea the flasher is for the turn signals. to control the flashing of the turn signals.
Old 01-30-2010, 03:43 PM   #4 (permalink)
Toyota Addict
Gameroom cash: $190660
View clintj's Photo Gallery
Big button right smack dab in the middle of the dash between the air vents!
clintj is offline   Reply With Quote
Old 01-30-2010, 03:46 PM   #5 (permalink)
Toyota Addict
BTW - When I opened this thread I was hoping to see a picture of a chick showing some breasts or something!
Old 01-30-2010, 04:08 PM   #6 (permalink)
Old Fart
mmasse's Avatar
Gameroom cash: $261903
View mmasse's Photo Gallery
Here ---->
I carry a gun because a cop is too heavy.
mmasse is offline   Reply With Quote
Old 01-31-2010, 08:26 AM   #7 (permalink)
Just getting started...
XRSized's Avatar
Gameroom cash: $224014
View XRSized's Photo Gallery
Not sure where it's located but if you find out let us know. I figured the led flasher will give us the same issue as the Camry and we'd not be able to use the hazards when the key is out of the ignition so I went ahead and ordered load resistors instead. If you have good luck with the led flasher then let us know!
XRSized is offline   Reply With Quote
Old 01-31-2010, 10:27 PM   #8 (permalink)
yes i wanted to know where is the flasher module?
hmm.. i really want it in, and its kinda better if the lights werent on, so thats my opinion..
Old 02-01-2010, 07:14 AM   #9 (permalink)
XRSized's Avatar
That's what she said!
I would think it'd be by the gauge cluster as well, are you sure it's not around there somewhere. If it's not there maybe it's on the steering wheel then...
Old 02-01-2010, 02:01 PM   #10 (permalink)
btk
btk's Avatar
View btk's Photo Gallery
i even opened up my steering wheel comparment, the casing around it that is, and couldnt find the flasher module.. in the camry its apparantly located there..
_________________________
09 XRS | RX400H projector RETROFIT | LED tails | Full LED Swap | Trunk CCFL lights | INJEN CAI | RED calipers | Pivot 3 Throttle Controller | TRD lowering springs | Eonon In Dash DVD&GPS | Nokya Hyper Yellow Fogs | Puddle Lights (coming soon)
btk is offline   Reply With Quote
