outlets dont work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2010, 12:35 AM   #1 (permalink)
littleboi64's Avatar
Gameroom cash: $284402
View littleboi64's Photo Gallery
outlets dont work
so recently, my lighter charger things stopped working. everything i plug in it does not work. Ive tried charging my phone and using a outlet converter. nothing works in all of these outlets. wondering if anyone had a fix. my aftermarket mods are 4100K PIAA bulbs and 2500K nokya bulbs. and the problem occurred before i installed my fogs. thanks if you got a fix.
littleboi64 is online now   Reply With Quote
Old 02-02-2010, 01:24 AM   #2 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342266
iTrader Score: 7 reviews
Did you check the fuse?
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 02-02-2010, 01:39 AM   #3 (permalink)
yes and its connected
Old 02-02-2010, 02:28 AM   #4 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
but is it broken?
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 02-02-2010, 08:30 AM   #5 (permalink)
View ToxicBanana's Photo Gallery
Did you use a inverter?
Some inverter say they will do 300watts+ AC from your 12V DC plug but most plugs (not 100% sure about the Corollas) only support about 10amps, which is only about 100watts if you pull 300watts expect to pull 30amps+ and that can blow your fuses.
(I know you said you checked the fuses but I mention this anyways as I have seen this happen lots of times)
ToxicBanana is offline   Reply With Quote
Old 02-02-2010, 09:25 AM   #6 (permalink)
View hungt1999's Photo Gallery
check the fuse again, not just a visual check, pull out the fuse and try a new one. I would think there is only one fuse but just in case, check other fuses too.
if it is not the fuse, the other possibility is wiring problem
hungt1999 is offline   Reply With Quote
