I had one of those looking off to the side of the highway and then look back to the front to see brake lights and the rear end of the car in front of me coming at me fast and furious, so I stomped on the brakes and I actually felt the anti-lock mechanism kick in along with the gear grinding sound that accompanies it.
I'm just wondering if this is normal on dry pavement? I know in my Tundra my brakes would lock up on dry pavement and I would be rewarded with a nice rubber on pavement brake screech.
Is this a concern? The vehicle stopped in time, but I think on dry pavement I want the wheels to just lock up. Is that old school?
Old skool. I think of it as Assisted Braking while Steering.
If your wheels locked up you would lose the ability to steer while braking, and would just slide with the original direction of travel. By not locking up you wheels continue to roll allowing you to steer and avoid the obstacle.
__________________ '09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated) (original unflashed factory ECM code)
For almost any set of materials, the coefficient of sliding friction is much lower than the coefficient of starting friction. If you lock your brakes on dry pavement, potentially it'll take longer to stop than if you can modulate them to get to the point of sliding and then back off. Even if the ABS doesn't modulate fast enough to reduce the stopping distance appreciably, you do get the advantage that you retain the ability to steer.
In a panic situation like you had, traction WAS an issue! Also consider when someone goes into a panic and locks their brakes, and seeing themselves sliding towards the hazard don't realize that they should let go of the brake to regain steering control or at least be able to restore the lost traction and brake again, and instead just stomp even harder on the brake. ABS helps immensely in that case.
+1
Just hit the brakes & steer where you need to go.
__________________ 89 Supercharged White MR2 5-speed / 09 Corolla S CSM 5-speed
94 Corolla DX Red 5-speed / 95 Previa S/C White Auto/
One other thing to consider. You're in Maine...which (like Ontario) is sitting pretty cold right now. Probably below 32F.
So if you're using All Season tires, their traction is reduced below 5C (I think that's about 40F). That's basic physics and why so many people invest in winter tire rubber compounds that are better suited to near freezing temperatures. If Maine uses salt on the roads, then this too will reduce traction.
