Originally Posted by x8dragon8x
im just curious about why anyone would want to get a throttle controller or switch to a higher output alternator
A throttle controller is supposed to decrease the lag time between the pressing of you pedal and the fuel actually reaching the engine.
The stock alternator is only rated at about 100 amps and a decent system or other larger electrical systems will suck that up and then some easily. This causes a lot of strain on the alternator and can be bad for other electric systems on the car. I plan on upgrading when I can afford. My sound system easily dims my headlights to almost nothing and if I am idling with my system up after a minute or two my car will start to idle rough. It also requires a 150amp fuse so it is sucking most of what the stock alternator is putting out.
