Do the vibrations stop when you put your hand/finder on the offending part? If so, you could try so varying sizes of back packing foam, and jam it between the meeting surfaces. I did this on my other vehicle with great success.
__________________ '09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated) (original unflashed factory ECM code)
well, i tried jumping into the back seat for just a second while on the hwy, but i didnt have enough time to massage the back deck, the car started to drift, needed to get back into the drivers seat
i tried this on the drivers door pillar, tried moving the seat belt height, still a buzz. i'll need to get a buddy to sit in the back to handle the rear deck vibration.
my 10 XRS has some annoyoing rattles. they all come from road vibration.
1. the passenger side rear deck, sometimes i get a rather noticeable rattle.
2. the door pillars, i get a low bee buzz, on & off, quite annoying.
My 09 does that too, rattled took it in to fix it. After 2 days got the car back still rattles, only now not only in the right pillar area but the driver side too. I notice it a lot when standing at the light, everything rattles while my car is in idle.
For those with the bee buzz in the B-pillar - check this out.
There's a rubber seal around the inside of the window frame - presumably to buffer the window from hitting the metal door. When you hear this buzz, try holding down on the seal in several places.
I've discovered that it's the rubber which is sticking to the metal frame in the top/rear corner and during highway road vibrations will "jiggle" and make this bee sound.
I haven't fixed it yet - was gonna try and run a clean cloth inbetween the door and rubber seal to see what happens - maybe even add a spot of silicone in there to keep it from sticking. We'll see.
rolla-XRS,
mine seems to be road related and not wind related. i can roll real slow on a rough road and i get the buzz, but at speed i hear the same buzz, the level never changes. i'll investigate more tomorrow.
rolla-XRS,
I understand. Mine was not wind related either.
Vibration from the ROAD is causing this rubber seal to stick and squeek against the door frame. If it was wind, the noise would remain if I touched the seal from inside the car.
my noise is coming from above the headliner, directly above the B pillar. sounds like a plastic clip was left up there and it found a resting place, and it makes noise as it vibrates there. i have not yet fixed it, but thats where the noise is coming from....
If it's still under warranty than take it by the dealer.
__________________ 89 Supercharged White MR2 5-speed / 09 Corolla S CSM 5-speed
