Fuel Induction Service - question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2010, 12:28 PM   #1 (permalink)
View Lit'l Cat's Photo Gallery
Hi Yall
I have a 2009 xle - purchased May 2008 & have 17K miles. (Also have Toyota ext. warranty)
On last oil change/15K service - dealership kept pushing the Fuel Induction System Clean-up ($125.00 us)
I asked to put it off a few months. They said had to be done & thats why my mpg has fallen slightly (as opposed to the cold weather). I still havent had it done.
Is this an important maint thing? According to the warranty info, nothing says it should be done.
What are everyone's opinions on this?
0
15k cost me $170 & 30K maint almost $300
Thanks
Lit'l Cat
Lit'l Cat is offline   Reply With Quote
Old 02-19-2010, 12:53 PM   #2 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521219
View LeanBurn's Photo Gallery
Canada
I am going to have to call BS on this 'service' at this mileage. Looks like the dealer wants some easy money. If you are concerned, go buy some Techron, its one of the best out there.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 02-19-2010, 01:00 PM   #3 (permalink)
Ask your Mother
sinnaever's Avatar
Gameroom cash: $283734
View sinnaever's Photo Gallery
Originally Posted by Lit'l Cat View Post
Hi Yall
0
Thanks
Lit'l Cat
to me it sounds like they want to a Throttle Body Clean & Fuel Injector Clean...
I suggest using a Fuel System Cleaner like
STP's Complete Fuel System Cleaner... it costs $13 or less, and can be found at Wal-Mart, Target, Canadian Tire, just about anywhere.
A fraction of the cost, and similar results
2009 Corolla XRS
2006 Matrix XR
sinnaever is offline   Reply With Quote
Old 02-19-2010, 01:36 PM   #4 (permalink)
Thanks for the info.
Have a ? for you Leanburn - how is your milage so good? Is it flat in your area? I was getting b/t 34-35mpg (figured manually 50/50 driving) last summer now around 32 mpg. I go 55-60 on hwy, accelerate slowly, coast to stop light etc... Granted, it has been a really cold winter for us but I havent changed my driving (well, heater on #2) Plus, I dont 'warm up' car in morning - just start & go
Old 02-19-2010, 04:02 PM   #5 (permalink)
LeanBurn's Avatar
Canada
A couple of tips:
My commute is 95% highway, relatively flat land except for 2 hills.
- I 'drive with load' (gently accelerate before the hill and let it take my excess speed, then gently accelerate back up to cruising speed) after the hills,
- I 'drive without brakes' (coast as much as possible to avoid using the brakes).
- I also pull away from stop as gently as possible (2000rpm is my ceiling).
- Never warm up the car sitting there I tool down the street below 1500rpm and then gently get up to cruising speed, (I use block heater 10 degrees below freezing 3 hours prior to leaving). My car rarely sees over 2500rpm.
- I let the car reach operatiing temperature before turning on the heat defrost and at highway speed I use defrost (front and rear) as needed, I have a heated car seat cover.
I do all these out of habit on all my vehicles and can/and have beat EPA on every vehicle I have driven.
Old 02-19-2010, 04:03 PM   #6 (permalink)
View pwain's Photo Gallery
What service did they do at 15k to run $170?
+1 to LeanBurn. Along with gas, it saves wear and tear on ever aspect of your powertrain!
pwain is offline   Reply With Quote
Old 02-19-2010, 04:19 PM   #7 (permalink)
View ZO6_Vette's Photo Gallery
Just send me the $125 and I will do it from here.
ZO6_Vette is offline   Reply With Quote
Old 02-19-2010, 06:02 PM   #8 (permalink)
Gameroom cash: $240090
View The7's Photo Gallery
[quote=Lit'l I was getting b/t 34-35mpg (figured manually 50/50 driving) last summer now around 32 mpg.[/quote]
If it is cold winter like recently in VA, then 32mpg in cold winter is reasonable when compared to 34/35mpg in summer.
The7 is offline   Reply With Quote
Old 02-19-2010, 10:34 PM   #9 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342266
iTrader Score: 7 reviews
Hi Yall
0
Thanks
Lit'l Cat
I call BS on it. At your mileage the system should still be in good shape. Just use high quality gasoline with a good fuel additive package like Shell or Chevron. If you ever need a good fuel system cleaner there is nothing better than BG 44K. It is a little more money at $20 but I've heard about dealers putting in a can & charging you the $125! If you used a can every 10k after maybe 25k miles on your car your fuel system would always be in top running condition.
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 02-19-2010, 11:39 PM   #10 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
im a regular user of STP products as well.
joeylgarcia is offline   Reply With Quote
Old 02-20-2010, 12:02 AM   #11 (permalink)
View goodman's Photo Gallery
Canada
I use fuel system cleaner every 5K before the oil change, around $10 per bottle. My friend use $3 bottle Lucas injector cleaner every month for his over 300K 15 years old accord. His mechanic said his injector was very clean.
goodman is offline   Reply With Quote
Old 02-20-2010, 08:59 AM   #12 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
It's my humble opinion that the level of system cleaning is directly proportional to your driving habits.
I try to run my car down to between 1/8 and 1/4 of a tank. Then fill it up completely from a Company that has an additive package that is recognized by most manufactuers.
http://www.quiktrip.com/gasoline/iq.asp
A tank of gas very rarely last more than a couple of days because I am a salesman and do a lot of highway driving. I change my fuel filters every 35K.
Never had a fuel related problem with any injector system.
The Blue Streak Slug
2008 Tundra TRD Offroad
OkSlim is offline   Reply With Quote
