Another mystery revealed! I just wish that the Mobil 1 folks would put 0W-20 in a gallon jug.
Corolla Maintenance Required Light Reset
1.Turn the ignition switch to the “ON” position.
2.Depress the odometer pushbutton until it indicates “Trip A” mileage.
3.Turn ignition Switch to the “ACC” position.
4.Push and hold the Odometer Trip Pushbutton.
5.While holding the Trip Pushbutton depressed, turn the ignition switch to the “ON” position.
6.The odometer window will show 5 dashes, then 4, then 3, 2, and 1, then flash all zeros and will return to the “Trip A” mileage indication.
7.Release the Odometer Trip Pushbutton.
8.The maintenance required light will be turned off and reset for 5000 miles from the the current odometer indication.
1996 Tercel 213,000 mi 38 MPG SOLD to fellow next door, still going strong!
2005 Camry LE
2010 Corolla S
I am annoyed how it comes up every 5000 miles, it's not on the same page as me because I change my Camry's oil anywhere between 4-6k
I'll always forget too... "why is this light coming up I just changed it 1k miles ago" haha
I'm with you on that one. I typically change my oil at the 4,000-4,500 mark, so now at 49,000 its all off. I *believe* you can reset the counter even without the light coming on. About 1.5 months from now I should be able to verify it.
8.The maintenance required light will be turned off and reset for 5000 miles from the the current odometer indcation.
There is this book called the Owner's Manual. If I have a ~$20,000 investment in something I usually read the owners manual.
Yes, you can reset the maintenance light without the light actually coming on. I change my oil every 4,000 miles and don't see it except for the lights check on startup!
Ahem... I read the owner's manual. Searching for info on the Internet is faster than doing a page by page search of the manual, if what you want to know isn't indexed the way that you're thinking about it. And sometimes the folks who write these procedures up don't lay the info out in a manner that is easy to understand.
2005 Camry LE
2010 Corolla S
As a side question, I wonder why we don't have the maintenance lights? Is it because Canadians in general are more aware of the maintenance intervals? Do the UK cars have the maintenance light? We all have this idea that Europeans in general are more one with thier automobiles.
__________________ '09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated) (original unflashed factory ECM code)
that's absurd... its just a matter of preference for the company to program the cars with or without the maint. req'd light
