Blank Accessory Plates? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2010, 03:07 PM   #1 (permalink)
View lightfxboy's Photo Gallery
Does anyone know how much dealerships charge for the blank accessory plates? I replaced the stock stereo in my 09 Corolla and I want to hide the AUX jack (no longer needed) behind the console and replace it with a blank.
I also took out a blank from near the mirror controls to put in a toggle switch. I can't use this blank to replace AUX jack as it is the wrong color. My question is, the toggle switch I put in for separate lighting is a bit smaller than the switch area where the blank came from. Does anyone know if Toyota make toggle switch adapter blanks. Sorry if that sounds confusing.
lightfxboy is offline   Reply With Quote
Old 03-09-2010, 04:06 PM   #2 (permalink)
ducksunlimited90's Avatar
View ducksunlimited90's Photo Gallery
I'm not sure if they make a toggle switch accessory plate but I know from my dealership it was $10 per accessory plate.
ducksunlimited90 is offline   Reply With Quote
Old 03-09-2010, 04:41 PM   #3 (permalink)
Wow, $10 for that little piece. I wonder if there are any places online that sell it as an aftermarket place for a little bit less.
I thought about cutting a hole out in it to fit the toggle switch, but it's got all that excess plastic on the back. I figured it would've been hollow. Any other suggestions? I want it to look like it was supposed to be there and not all throw together, ya know?
Old 03-09-2010, 04:41 PM   #4 (permalink)
Does anyone even know the correct name of the piece I'm talking about?
Old 03-09-2010, 05:05 PM   #5 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $412712
View Jeff Lange's Photo Gallery
Blank Plate: 55539-02130-B0
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 03-09-2010, 05:11 PM   #6 (permalink)
Jeff: are these only available at dealerships or can they be found aftermarket?
Old 03-09-2010, 05:35 PM   #7 (permalink)
Jeff Lange's Avatar
I doubt you'll find any aftermarket. They're pretty cheap from Toyota though.
Jeff
Old 03-09-2010, 06:05 PM   #8 (permalink)
Boy Wonder
ChancreScolex's Avatar
Gameroom cash: $210651
iTrader Score: 6 reviews
View ChancreScolex's Photo Gallery
I cut a hole through one of mine to mount a toggle switch. It doesnt look thrown together at all. Just use a dremel and try to be as precise as possible. I cut the hole a bit small at first and then gradually widened it until I had a perfect fit.
2009 MGM Corolla S - My Garage
Debadged, Hood Dampers, Takeda SRI, 25/15 Tint, LED Dome/Map/License Plate Lights, Weathertech Rain Deflectors, Hella Supertones, Pioneer Premier AVIC-F90BT, 2 12" Pioneer Premier 1200w subs, Magnaflow Exhaust, TRD RSB/FSB/Springs, 18" Enkei EKM3's
ChancreScolex is offline   Reply With Quote
Old 03-09-2010, 06:12 PM   #9 (permalink)
Do you happen to know the measurements of the blanks and if they have an adapter of sorts for smaller switches? The switch I have is a little smaller than the area for the blank.
Old 03-09-2010, 06:44 PM   #10 (permalink)
I think you are confused. The switch will be smaller than the hole where the blank is. You use the blank plastic piece and drill a hole through the piece and hollow it out with a dremel then the switch fits through the hole and looks stock.
Old 03-09-2010, 06:56 PM   #11 (permalink)
I missed ChancreScolex post before I posted the last message. I have a drill, but no dremel. I'll have to see what I can do.
Old 03-09-2010, 08:03 PM   #12 (permalink)
I used sidecuts or whatever kind of pliers they are called and a sharp knife or razorblade. Dremel just makes it a lot easier
Old 03-11-2010, 11:03 AM   #13 (permalink)
TACO_KID's Avatar
Gameroom cash: $435915
View TACO_KID's Photo Gallery
they are out there for about $4-5 (http://www.trademotion.com/partlocat...?siteid=214001), just search for that part #, etc.
dunno if shipping will be $5, which leads you back to your local dealer, etc. many times local retail is inet price + shipping, etc.
TACO_KID is offline   Reply With Quote
