In case anyone wants to know about how to re-install a vapor barrier I thought I'd make a quick post on it. I needed to replace the passenger vapor barrier after I trashed the original installing sound deadening material for the door for my stereo install.
1. Called the dealership and ordered a replacement barrier. It was about $23 + tax.
2. Went to Advance Auto and picked up a package of 3/8" x 15' 3M Windo-Weld. It's the sticky stuff that holds the vapor barrier to the door. $20 + tax
3. Since the Windo-Weld stuff comes in a round format I just cut off (scissors work great) a section and using the existing channel in the door laid down a fresh bead of the Windo-Weld material.
4. Take the new vapor barrier and using firm pressure with your thumb press the vapor barrier into the new bead of Windo-Weld you just laid down. You could also LIGHTLY heat the Windo-Weld with a hair dryer to really make it stick.
5. That's it, done. YOu now have a new vapor barrier installed. Since the roll I bought has 15' of material and I stretched the pieces I cut off, you could probably do all four doors if you wanted.
Hope this helps.
