Satellite Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2010, 08:01 AM   #1 (permalink)
View cjkeenan's Photo Gallery
Canada Satellite Question
I just want to see if anyone knows if this kit can be installed and connected in the trunk of a base model 2010 corolla. http://www.tss-radio.com/toyota-lexu...ge-p-5709.html
I've seen some discussion that says yes, but wanted to double check. Also can I simply splice into the existing Sat antennae?
Thanks a bunch.
cjkeenan is offline   Reply With Quote
Old 03-17-2010, 03:41 PM   #2 (permalink)
View sienna1's Photo Gallery
Canada
It will work (plug-n-play) except for the antenna's connection. You can either splice or purchase an adapter for the antenna connection.
sienna1 is offline   Reply With Quote
The Following User Says Thank You to sienna1 For This Useful Post:
cjkeenan (03-18-2010)
Old 03-17-2010, 04:59 PM   #3 (permalink)
View pwain's Photo Gallery
Yeah, all you will need to do is splice the wires, as I don't reccomend people buying a $70 adapter to do the same thing.
If you already have XM installed, you could switch your account over. Same programming at this point.
pwain is offline   Reply With Quote
The Following User Says Thank You to pwain For This Useful Post:
Old 03-18-2010, 12:02 PM   #4 (permalink)
would i have to solder the splice or will a good tape job do?
Old 03-18-2010, 05:14 PM   #5 (permalink)
qcfc88's Avatar
View qcfc88's Photo Gallery
I soldered the two wires together, I'm not sure if a tape job would work very well. It was pretty easy to do, actually ...
qcfc88 is offline   Reply With Quote
The Following User Says Thank You to qcfc88 For This Useful Post:
cjkeenan (03-19-2010)
