With those specs, its complete garbage, you wont achieve much with a
Pr of 1.45 and it draws up to 350 amps, when your original amps is capable of max 100amps.
Regular turbo achieve
PR of 3 and up to 7 with specialized alloys..pressure ratios are limitied to physical material properties
Specification Summary
Maximum Pressure Ratio 1.45 Maximum Speed 70,000rpm Time to Maximum Speed <350ms Peak Shaft Power 1.8kW Current Draw - Idle 1.5 Amps Current Draw - Acceleration 350 Amps Current Draw - Steady State 220 Amps
