Possible 2010 Stability/Traction Control Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2010, 12:13 PM   #1 (permalink)
TACO_KID's Avatar
Gameroom cash: $435915
View TACO_KID's Photo Gallery
i have to do more testing, but the other day while making a left turn the car seemed to just lose power, and then pick back up again. i was stopped, and went to accelerate while turning into a left turn (a wide left turn, but in the end of the turn i had to put more wheel into it to keep in the lane, etc), at the moment i put more wheel into it the car just went limp, and then resumed.
so my question is, does either stability control or traction control (on this vehicle) cause the engine to reduce power, or cause the transmission to de-couple during certain conditions?? i didnt notice rpm's on the gauge, but i didnt hear a rev. my foot was steady on the gas pedal.
2010 XRS 5sp auto
TACO_KID is offline   Reply With Quote
Old 04-30-2010, 02:01 PM   #2 (permalink)
Gameroom cash: $240090
View The7's Photo Gallery
VSC/TC will only cause the engine to reduce power.
The7 is offline   Reply With Quote
Old 04-30-2010, 04:48 PM   #3 (permalink)
View ZO6_Vette's Photo Gallery
VSC can apply individual wheel brakes or reduce power.
You just might have pushed it too hard and Mr Toyota came to your aid.
ZO6_Vette is offline   Reply With Quote
Old 04-30-2010, 05:01 PM   #4 (permalink)
TACO_KID's Avatar
thats the issue, it wasnt a hard push into the turn, nothing i would expect to cause the engine to reduce power. i would consider it to be dangerous considering the turn i was taking. if i needed to really jam the gas to avoid a accident i would not have been able to at that moment. i'd say it was on the order of 1+ sec but less than 2sec, which can make a diff in some cases.....
if it was VSC then it is way too sensitive, perhaps dangerous.
Old 04-30-2010, 07:14 PM   #5 (permalink)
The Corolla That Could
shotgunjimmy's Avatar
Gameroom cash: $213000
View shotgunjimmy's Photo Gallery
USA
2010 XRS 5sp auto
by de-couple i assume you mean stop driving both wheels? as far as i know, and unless youve purchased and installed the TRD limited slip diff, the transmission is already "de-coupled", so if you did a burn out for instance, only the wheel with less traction would spin. I dont think this is the case with your car.
My bet is that while making the turn the variance in wheel speed bewteen outside and inside wheels was too great, causing the car to think you were losing traction, and killing power.
my advice, go play around in an empty parkling lot and try and duplicate this situation. if its easily duplicated, take it to the dealer and have them check it out.
shotgunjimmy is offline   Reply With Quote
Old 04-30-2010, 07:54 PM   #6 (permalink)
thestone11's Avatar
Gameroom cash: $366887
View thestone11's Photo Gallery
Canada
You should try it with and without the Traction control as well.
1985 Corolla GTS (AE86)
2002 Mazda Protege 5 (Sold)
2009 Corolla S: http://www.cardomain.com/ride/3820536
thestone11 is offline   Reply With Quote
Old 04-30-2010, 08:24 PM   #7 (permalink)
TACO_KID's Avatar
i will try the same turn w/ and w/o VSC.
my concern is, the turn i took (imo) should not have caused VSC to kick in, and in my case i think its more dangerous to have it do what it did, it was clean dry pavement so i doubt the wheels were slipping that much.
Old 04-30-2010, 10:56 PM   #8 (permalink)
I doubt it but you could have a loose yaw rate sensor.
Old 05-01-2010, 10:35 AM   #9 (permalink)
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Gameroom cash: $105560
View rolla-XRS's Photo Gallery
Alas, one more reason to strangle Congress. Really...did they have to force manufacturers to criple our cars with all this mandated technology...just because people drive too fast for the conditions? IMO - VSC and Traction Control are unnecessary.
As for reducing power, I've stupidly taken some pretty hard turns and can't complain. However if one of my turns is too hard and one of the wheels starts to slip, then yeah power will be reduced so that the wheel regains traction Normal operation.
rolla-XRS is offline   Reply With Quote
Old 05-01-2010, 11:46 AM   #10 (permalink)
TACO_KID's Avatar
same goes for the new Avatar blue-ray dvd discs. apparently the encryption track has newer protocol than many blue-ray dvd firmware can support, and until the firmware is updated (if it can be) the dvd will not play.
sometimes technology is the enemy to enjoying the purchase. i know my xrs has the VSC off switch, but for cases where wheels do slip beyond my control i like the technology to do its job. in my case no wheels were slipping, but perhaps in the turn the diff in wheel rpm's caused the sensor to kick in, something i was not expecting it to do, etc.
Old 05-01-2010, 08:07 PM   #11 (permalink)
Gameroom cash: $142705
View liljpboi's Photo Gallery
Yeah I've heard many people having this problem before as well including myself its not the TRAC though its the damn VSC that does it... TRAC is actually pretty useful however I hope VSC can go to hell =D
liljpboi is offline   Reply With Quote
Old 05-01-2010, 11:24 PM   #12 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1341366
iTrader Score: 7 reviews
I know this is off topic but I had to say that the Avatar Blu-ray played great on several of my Blu-ray players & looked awesome on my 106" front projector in my theater room!
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 05-03-2010, 05:36 AM   #13 (permalink)
Ask your Mother
sinnaever's Avatar
Gameroom cash: $283134
View sinnaever's Photo Gallery
Zero issues on my PS3...
Oh, and I have not experienced anything like the OP is describing. I have taken some wicked awesome corners that the Wifey got mad at me for taking and NO loss in power
2009 Corolla XRS
2006 Matrix XR
sinnaever is online now   Reply With Quote
