Can I program the door locks myself?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2010, 12:13 PM   #1 (permalink)
FirstCorolla's Avatar
View FirstCorolla's Photo Gallery
I would like to change the door lock program. It is currently set to default where it locks when I shift from park.
I would like to change it to locking when I reach 12mph as the owners manual says can be done.
Does anyone know if I can do this or must I make the 40 minute trip to the dealer?
Any help is greatly appreciated.
Thank you.
2010 S Auto
FirstCorolla is offline   Reply With Quote
Old 05-03-2010, 12:31 PM   #2 (permalink)
10 Corolla S, 11 H/L SE
View thewalrus2010's Photo Gallery
Originally Posted by ChancreScolex View Post
It's documented on page 41 of the owners manual, but here are the steps for what you want to do:
1. Close all doors and put key in and turn to on position (do not start car).
2. Within 10 seconds of perorming step one, press and hold the door unlock button for approx. 5 seconds and release.
Door locks should lock and unlock to confirm the operation is complete.
thewalrus2010 is offline   Reply With Quote
Old 05-03-2010, 12:51 PM   #3 (permalink)
Ahh so it is! I shouldn't admit this... but I even remember reading that now that I see it again...
Thanks.
Looks like I have to perform it 2 times to accomplish my goal. Once with P to cancel the default setting and once with N to program the speed sens locking.
2010 Black S-Low&Fog 6K HID,led lighting/cup holders/ash tray/center con pockets,Trunk pop mod,Fog light mod,No seatbelt beep,Hood dampers,Chrome wheel skins,Side marker lights,WeatherTech,Auto mirror w/homelink,Frt & RR DVD's,rear camera,bluetooth,
Old 05-04-2010, 09:02 AM   #4 (permalink)
Got this to work. I had tried it over and over and it did not work. Found some tips on the net and now it works. Sounds strange but if it does not work for you... pull the e brake up and the dome light must be off. I did those things and it works fine everytime. Strange.
Old 05-04-2010, 09:36 AM   #5 (permalink)
View conbo3's Photo Gallery
Originally Posted by FirstCorolla View Post
Okay so I have tried this MULTIPLE times. Over and Over. I also tried every variation that I could think of. This absolutley does not work in my car. My car gives no indication at all that I am trying to program anything. No response.
Reading the manual carefully it appears that some of the programing can be done only on the car with the smartkey. However some can be done on the car without the smartkey. Is that right? My car does not respond to any of it.
Am I missing something here? Has anyone done this in a 2010 and had it work?
If it helps at all, I am in a 2010 S with no smartkey fob. (I have the key with the lock/unlock buttons on the key).
Thanks
I programmed my 2009 Corolla LE per those directions ok. It took the first time I did it. I didn't mess with the unlock function and the locks unlock when I shift to Park. That doesn't bother me as much. I do NOT have a Smartkey fob. It takes a good long time to figure out WHAT you have by reading he one-size-fits-all Users Manual. Does the 2010 manual still have those instructions on pg 41? It seems to me that the electronics people at Toyota do not talk to the automotive engineers and vice versa.
conbo3 is offline   Reply With Quote
Old 05-04-2010, 09:44 AM   #6 (permalink)
View lightfxboy's Photo Gallery
I have a 2009 LE and I cannot get this to work. I'm trying to change the setting to lock at 12 mph. I've followed the instructions per the manual with no luck. Ebrake on and off no light on, etc. no luck. Any ideas?
lightfxboy is offline   Reply With Quote
Old 05-04-2010, 10:01 AM   #7 (permalink)
Yes those instructions are still there. Still a little muddy clear though.
Okay here is what you do.
Ebrake on (in my car it DOES NOT work with the ebrake down - i tried over and over)
dome off or on door
turn key to on
leave in park
wait until you hear the seatbelt chime QUICKLY press and hold the lock button on the drivers side door. Release it at the same time the seatbelt chime stops. (I think it chimes 5 times)
The doors will make a locking sound to show it worked.
turn key off
THEN
turn key on
Quickly shift to N so you can press and hold the lock button again as soon as the chiming starts. Release lock button at same time chiming stops.
The doors will again make a locking sound.
RESULTS:
Your car will auto lock when you hit 12MPH and auto unlock when you shift into P
TIMING IS EVERYTHING. Hit that lock button AS SOON AS the chiming starts and time the release to be right when the chiming stops.
Old 05-04-2010, 10:11 AM   #8 (permalink)
Mods-Sticky in FAQ please?
dome off or on door
turn key to on
leave in park
turn key off
THEN
turn key on
RESULTS:
Old 05-07-2010, 07:59 PM   #9 (permalink)
Metal Maniac
View General Klinger's Photo Gallery
Stupid question but I have to ask....
Can you program for auto-lock on a 5spd? My Corolla S does not auto-lock currently and it's annoying to have to keep hitting the damn button. Can it be done?
General Klinger is offline   Reply With Quote
