Im Stuck! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2010, 10:32 AM   #1 (permalink)
View Danny79's Photo Gallery
Im Stuck!
Here is my problem. I bought a '10 Corolla, I had the HID's done to the headlights and I still get the same problem wether the car is off or on. When I turn my headlights on the hid's turn on and immedietly turn off under half a sec. So I read and researched the forums and did everything you can think of. I switched out the ballast, I added a relay, changed the relay again in case it was a bad relay, I disabled my DRL's. Still does the same thing. The Hid's that I bought were from ibrite 35w. Btw after I turn the headlights off and on a few times they work. Its the initial start.
Im Stuck! Any suggestions anyone?
Danny79 is offline   Reply With Quote
Old 05-04-2010, 12:00 PM   #2 (permalink)
Gameroom cash: $240090
View The7's Photo Gallery
The problem could be the HID unit.
Test the HID unit directly.
The7 is offline   Reply With Quote
Old 05-04-2010, 01:21 PM   #3 (permalink)
View 87phantom's Photo Gallery
Based on what you said, the problem seems like it occurs at initial start-up. If that's the case, the ballasts are not getting enough power to start-up. You said you installed a relay? How did you install it? Is it a relay to get power directly from the battery? You need a full relay harness that supplies power from the battery to fire up the two ballasts.
87phantom is offline   Reply With Quote
Old 05-04-2010, 01:24 PM   #4 (permalink)
Broken Legged S Owner
RjKlement15's Avatar
Gameroom cash: $233500
View RjKlement15's Photo Gallery
While on the subject of HIDs... I know all cars are different. Is the 10th gen A single bulb for high and low beams with the electromagnet and the DRL is the one that separate, or are the High and low separate bulbs, I know my old BMW was both and Im too cheap to buy two sets.
2010 Corolla S - K&n typhoon SRI - NST Underdrive Pulley - Weapon R header - Spintech Performance exhaust - JL 12W7 - Alpine Head Unit - Really hot girlfriend In Passenger seat
RjKlement15 is offline   Reply With Quote
Old 05-04-2010, 01:30 PM   #5 (permalink)
Its a full relay harness, It hooks up to get power directly from the battery. I called several places and everyone seems baffled at the symptoms. My only 2 other things I can try is checking the power coming out of the battery. 2) Is take out the whole HID unit and try it on the bench to make sure its not the actual Unit even though i was told the ballast was switched out. Perhaps just a crappy brand?
Old 05-04-2010, 01:33 PM   #6 (permalink)
My DRL's and High beams are on the same bulb. The Lowbeam runs off by itself.
Old 05-04-2010, 01:34 PM   #7 (permalink)
It has a dedicated bulb for low beam and a dedicated bulb for combined use of DRL and high beam. The low beam bulb is a 9006 bulb type. There is no need to have HID high beams anyway since you will need it instantly to flash people - HID will delay the flash by 2 or 3 seconds due to start-up time.
I tried a plug and play HID kit in my 10th gen, but there was too much glare. The light output was scattered everywhere, making it unsafe for you and oncoming traffic. Best way to have HIDs is to do a projector retrofit, which I'll be doing soon.
Old 05-04-2010, 01:38 PM   #8 (permalink)
Could be a defective relay harness too....
Old 05-04-2010, 03:40 PM   #9 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
defective bulbs or defective ballast?
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 05-04-2010, 04:26 PM   #10 (permalink)
TACO_KID's Avatar
Gameroom cash: $435915
View TACO_KID's Photo Gallery
do the HID bulbs match the ballast unit? i suspect the ballasts are entering some sort of auto-off mode, perhaps too much current during their start-up period or you are only seeing the start period, so they look like they are starting to light but never actually start HID and then the ballast quits start-up period? perhaps try the bulbs on a different ballast, if they light ok then your ballasts are probably wacky.
TACO_KID is offline   Reply With Quote
Old 05-04-2010, 07:27 PM   #11 (permalink)
Persian Scarface's Avatar
Gameroom cash: $427750
View Persian Scarface's Photo Gallery
well i never heard of ibrite, so i could just be a crappy brand lol, but who knows thats really weird
flickr
RIP Zyzz
2010 Super White Corolla S
17% tint | DDM Tuning 35w 6000k lows/fogs w/independent mod | complete LED swap | red-out tails | Borla Pro XS Exhaust | Gloss Black Roof
Persian Scarface is offline   Reply With Quote
Old 05-04-2010, 08:44 PM   #12 (permalink)
FlameyFart's Avatar
Gameroom cash: $207875
View FlameyFart's Photo Gallery
I'm stumped, too...
If everything is ok, then the last thing to check is the battery. Goodluck!
2010 Corolla LE (MGM)
FlameyFart is offline   Reply With Quote
