Fast Turn Signals? HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2010, 02:11 AM   #1 (permalink)
emerson323's Avatar
View emerson323's Photo Gallery
So just today I changed my LED tail light's original turn signal bulb to an led bulb which is this one ( http://www.v-leds.com/Exterior-LED/B...88382-1-2.html ). When I tried using the signal lights the blinks became 5x faster.. What causes the turn signals to blink faster? Is there any way to put back my turn signal's blink to normal pace?
Thankss alot!!!
1989 Toyota Corolla
emerson323 is offline   Reply With Quote
Old 06-10-2010, 02:28 AM   #2 (permalink)
CRT > LCD
ZenithTheTV's Avatar
Gameroom cash: $243382
View ZenithTheTV's Photo Gallery
Check to see all the lights are working, one of them might have burnt out. Also check the fuses.
ZenithTheTV is offline   Reply With Quote
Old 06-10-2010, 02:37 AM   #3 (permalink)
emerson323's Avatar
All the lights are working fine. The fuses are also good. Is there any other reason why this happens?
I tried putting back the original Bulb on and it blinked in a normal pace. Changed it again with the LED one it blinked faster.. Hmm..
1989 Toyota Corolla
Old 06-10-2010, 03:11 AM   #4 (permalink)
x8dragon8x's Avatar
Gameroom cash: $166470
View x8dragon8x's Photo Gallery
i read about this from somewhere. it has nothing to do with the fuses. the lights are working but because the led uses such low power from the car. i guess it blinks faster to compensate from the higher power received. what you need i think is a relay to slow it down. im not sure which one however i know if you do a search about it. you will find it.
x8dragon8x is offline   Reply With Quote
Old 06-10-2010, 03:15 AM   #5 (permalink)
emerson323's Avatar
I got the solution. I need to get those Load resistor kits. I got 1 from v-leds
1989 Toyota Corolla
Old 06-10-2010, 03:16 AM   #6 (permalink)
x8dragon8x's Avatar
my fault i meant the resistors. hella forgot. haha. yeah those slow it down to a normal pace. how are the turn signals though? do they look good?
Old 06-10-2010, 09:05 AM   #7 (permalink)
emerson323's Avatar
they look really good and beautiful. The red LEDs projects True bright red colors, so nice.. I also bought white leds for my back-up lights that too is beautiful and bright!!
1989 Toyota Corolla
Old 06-10-2010, 11:24 AM   #8 (permalink)
Gameroom cash: $240090
View The7's Photo Gallery
Glad that you find the solution.
But this resistor kit will bring the overall electrical power consumption of the resistor and the v-leds back to that of the stock bulbs.
If you change the flashing unit to a solid-state flashing unit, then the resistor kit is not required.
The7 is offline   Reply With Quote
Old 06-10-2010, 12:28 PM   #9 (permalink)
littleboi64's Avatar
Gameroom cash: $283902
View littleboi64's Photo Gallery
they are called hyper blinkers. they are VERY bad for the lifespan of your turn signals. buy this asap and install it in. http://www.v-leds.com/Load-Resistors/c343525-1-2/ i forget which one is the one you need though :/
littleboi64 is offline   Reply With Quote
Old 06-10-2010, 01:11 PM   #10 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
you could buy load resistors or just get a led flasher relay which doesnt involve cutting or tapping wires.
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 06-10-2010, 03:26 PM   #11 (permalink)
emerson323's Avatar
Whats a solid-state flashing unit? how does it work and where can I get one?
@all Thanks for the help!!
1989 Toyota Corolla
Old 06-10-2010, 03:47 PM   #12 (permalink)
flamedrgn's Avatar
http://www.v-leds.com/Electronic-LED...s/c122487-1-3/
i think one of these would be better than some load resistors. but i have no clue what size or type you would need.
Bay Area Corolla
Old 06-10-2010, 03:54 PM   #13 (permalink)
emerson323's Avatar
I have a 1156 led bulb in my rear turn signals and 3157 led switchbacks turn signals in the front.
1989 Toyota Corolla
Old 06-10-2010, 04:03 PM   #14 (permalink)
flamedrgn's Avatar
you need to find out which electronic led relay replaces/fits in the oem denso flasher relay slot. replace the oem flasher relay with the led flasher relay and your hyper blinking will go back to normal.
Bay Area Corolla
Old 06-11-2010, 10:48 PM   #15 (permalink)
btk
btk's Avatar
View btk's Photo Gallery
I have tried locating the OEM flasher relay by opening up the steering compartment, but I was not able to find it. I have a LED flasher unit from V-LEDS and I'm waiting to put it on and swap out my turn signals for leds.. anyone knows how to locate the stock flasher relay?
_________________________
09 XRS | RX400H projector RETROFIT | LED tails | Full LED Swap | Trunk CCFL lights | INJEN CAI | RED calipers | Pivot 3 Throttle Controller | TRD lowering springs | Eonon In Dash DVD&GPS | Nokya Hyper Yellow Fogs | Puddle Lights (coming soon)
btk is offline   Reply With Quote
