towing with a 1.8 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2010, 12:18 PM   #1 (permalink)
rieds
Gameroom cash: $145495
View rieds's Photo Gallery
towing with a 1.8
is it feasable to tow 1000-1500lbs with a 1.8? not on a regular basis just a few times a year for a couple hundred miles. my trailer weighs 450 and quad 600. for towing i should leave it in 3rd with the auto tranny correct?
rieds is offline   Reply With Quote
Old 08-24-2010, 12:22 PM   #2 (permalink)
View DocUnissis's Photo Gallery
Originally Posted by rieds View Post
is it feasable to tow 1500-2000lbs with a 1.8? not on a regular basis just a few times a year for a couple hundred miles.
I towed my 950kg boat at the beginning and end of the summer for about 100km of highway driving plus 50km of country road on my old 2001 Corolla S (standard) and never had a problem. I forget how big its engine was.
NOTE: There were no steep hills on the route I took, and very little in the way of stopping.
DocUnissis is offline   Reply With Quote
Old 08-24-2010, 12:22 PM   #3 (permalink)
10 Corolla S, 11 H/L SE
View thewalrus2010's Photo Gallery
No I would really not recommend it. The max towing payload is 1500 lbs, and that's not including you and your stuff in the car. The motor is not strong enough and you will burn out your brakes in a hurry.
thewalrus2010 is offline   Reply With Quote
Old 08-24-2010, 12:45 PM   #4 (permalink)
No More Turbos!
View Pwner Guy's Photo Gallery
Unless you have a large trans cooler on your car you'll cook your transmission. You could probably tow the car with your quad and do less damage.
Richard Hammond - You can stick a BMW badge on a dead cat... And people would still buy it.
Pwner Guy is offline   Reply With Quote
Old 08-24-2010, 01:01 PM   #5 (permalink)
rieds
i have a dirt bike that weighs 150, and it would be nice for hauling small stuff like building supplies so i may go ahead and do it. the only thing i'm worried about is my borla muffler. not sure if it's in the way.
Old 08-24-2010, 01:06 PM   #6 (permalink)
thestone11's Avatar
Gameroom cash: $366887
View thestone11's Photo Gallery
Too much for a 1.8L
1985 Corolla GTS (AE86)
2002 Mazda Protege 5 (Sold)
2009 Corolla S: http://www.cardomain.com/ride/3820536
thestone11 is offline   Reply With Quote
Old 08-24-2010, 01:38 PM   #7 (permalink)
It needsa muffler bearing
Gameroom cash: $127577
View ej063090's Photo Gallery
I wouldn't tow with a car in general.
2010 Corolla S Black-Auto-Fujita SRI-Debadged -Mobil 0W-20 Oil-Nokya Yellow Fogs-All led swap-TRD FSB-TRD Lowering Springs-DDM 6k HID-Shift boot/CF Shift Knob-20/35 Tints-Tenzo r Cuzco Wheels-SmokeTail Lights
On the way: Borla exhaust-DC Sports Headers
ej063090 is offline   Reply With Quote
Old 08-24-2010, 01:40 PM   #8 (permalink)
on full afterburner
Gameroom cash: $1347897
If the entire payload (including you, whoever you carry and the trailer plus its contents) is under 1500lbs, then you are good.
I would recommend investing in a transmission cooler and following your factory owners manual to the T on towing.
Old 08-24-2010, 04:00 PM   #9 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521219
View LeanBurn's Photo Gallery
Canada
I wouldn't.
I have yet to see a quad weight 600lbs. If you have any fluids or gear on your quad it weighs more than you think. Plus anything in your car and the driver or passengers and you can easily go over. Any hills along your route can really over work the transmission and engine as well.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 08-25-2010, 01:29 AM   #10 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342266
iTrader Score: 7 reviews
I saw a 10th Gen Corolla towing a small trailer yesterday, it looked like it was not having any issues. Like others have said, just install a trans cooler & make sure the weight is okay. I used to pull a 18' boat with my 91 Camry with a 2.0L without issue.
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 08-25-2010, 02:36 PM   #11 (permalink)
rieds
how does the 1.8 compare with the 2.0 in a rav4? my rav was rated for 6000. i guess the tranny was a lot beefier. it pulled 2500 like a charm. what kind of tranny cooler do i need? the tranny lines run in the radiator. do i need one with a seperate radiator in front of the coolent radiator with a fan? mechanic at the dealer said it should be fine. but there not always the brightest.
Old 08-25-2010, 02:55 PM   #12 (permalink)
What year Rav? The 2006+ ones are either 2.4 I4 or 3.5l V6. I also doubt it was rated to pull 6000#'s. The new ones with the V-6 are only rated to pull 3500 lbs with the tow package.
Old 08-25-2010, 11:30 PM   #13 (permalink)
350whp grocery getter
v8eaterWRX's Avatar
Gameroom cash: $185410
View v8eaterWRX's Photo Gallery
Its not just about the weight and motor when it comes to towing. It is rated at a certain weight because the car is only safe at a certain weight. Sure I could throw 25klbs behind the F350 but that doesn't mean it is safe. It would pull it, but what happens when it has to stop, the wind starts blowing, or the trailer gets out from under ya?
v8eaterWRX is offline   Reply With Quote
Old 08-26-2010, 11:39 PM   #14 (permalink)
rieds
my bad i meant 2000. it was a 2002 2.0l
Old 08-27-2010, 12:41 AM   #15 (permalink)
Diehard Rams Fan
I saw a Yaris towing a trailer today!
