Originally Posted by FlawedLegacy
i cannot recall off hand, but i know it is in the manual for door lock programming
Tried for the last half hour what is in the manual and, I still can't get it back to the default setting.
There is something very odd happening.
Here is what has happened since trying what the manual recommends.
After getting out of the car, I locked the doors with the remote.
Used the remote to unlock the drivers door and it worked but, the other three doors wouldn't unlock as per usual when pressing the unlock button quickly a second time.
Got to the point where once I unlocked the drivers door, it would instantly lock again by itself.
At that point I had to use the key to unlock the drivers door.
Only by being faster in turning the key before it locked by itself again, was I able to unlock the door.
From that point on, I kept the window down!
At one time, I was actually able to drive the car without the door locking even doing more than 30mph.
Thought I had it back to normal.
Doors locked when I took it out of park while the car was started.
Doors unlocked when I put it back into park.
After putting it in park, I had one of the doors open as I was taking stuff out of the car, and then, the doors all locked by themselves, even with the door still open.
I didn't touch the key fob at all.
It's almost like it's on the setting where the doors automatically lock again after a certain period of time if you don't open one of them once you've pressed the unlock button on the fob.
Has anyone else had this kind of problem?
I was not trying to change the door locking/unlocking process when all of this first started.
Just accidently hit a button on the fob as I was getting out of the car.
I've done that a couple of times before and nothing like this happened.
