There are two plugs that plug in near the kick panel on both the drivers and passengers side. Once those are unplugged, you can pull the harness through towards the door. The hole in the Door jam is kinda small, so the plugs need to be worked through one at a time. When you pull it out, pull the grommet out too.
2009 Corolla S : Kenwood Kdc-x993, Polk MMC6500, Polk db651, Rockford Fosgate T110D2, Alpine Pdx.5
Magnaflow 2.25" Muffler, TWM Short Shifter and Base Bushings, Summit Engineering Shifter Cable Bushings, Tein S-Techs, V-Leds LED's, Enkei RPF-1 (18x8 +35), Inno IN-SU Roof Rack.
