ABS and Handbrake Light on?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2010, 08:22 PM   #1 (permalink)
View ericgu22's Photo Gallery
Any one know wat the problem is? still drivable?
ericgu22 is offline   Reply With Quote
Old 12-14-2010, 08:33 PM   #2 (permalink)
The Corolla That Could
shotgunjimmy's Avatar
Gameroom cash: $213000
View shotgunjimmy's Photo Gallery
check the brake fluid. sometimes low fluid in the resivior can trigger the brake light. if thats ok, id check and make sure the hand brake is infact not engaged, and that the switch on the brake handle isnt stuck. this would require disassemply of the center console (not hard at all).
2009 Corolla S : Kenwood Kdc-x993, Polk MMC6500, Polk db651, Rockford Fosgate T110D2, Alpine Pdx.5
Magnaflow 2.25" Muffler, TWM Short Shifter and Base Bushings, Summit Engineering Shifter Cable Bushings, Tein S-Techs, V-Leds LED's, Enkei RPF-1 (18x8 +35), Inno IN-SU Roof Rack.
shotgunjimmy is offline   Reply With Quote
Old 12-14-2010, 08:59 PM   #3 (permalink)
The random one
Gameroom cash: $121516
View MiniPacou's Photo Gallery
any electrical modification lately?
Got HIR?
MiniPacou is offline   Reply With Quote
Old 12-14-2010, 09:00 PM   #4 (permalink)
Well took it out for drive on a slippery surface. The ABS is not working so I guess its not the fluid?
Old 12-14-2010, 09:36 PM   #5 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342266
iTrader Score: 7 reviews
Time to see a dealer.
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 12-15-2010, 12:41 AM   #6 (permalink)
himmie's Avatar
View himmie's Photo Gallery
I had those two lights come on (along with another that I cannot recall) when a speed sensor broke in the rear wheel. I had to have the whole hub replaced. Ugh. Yes, time to go see the dealer...
EDIT: The VSC light was also on.
2008 Tacoma TRD Off Road 4x4
2009 Corolla XRS
himmie is offline   Reply With Quote
Old 12-15-2010, 12:05 PM   #7 (permalink)
Currently, I used the 10 corolla's steel rim on my S which is 15inch. Would not damage something? I believe all have 5x100 bolt pattern. Woud'nt all Corolla have the same caliper clearance,etc....
Old 12-15-2010, 03:34 PM   #8 (permalink)
nike air max
got-rice's Avatar
Gameroom cash: $890604
View got-rice's Photo Gallery
+1...enough self-diagnosis, take advantage of the warranty.
got-rice is offline   Reply With Quote
Old 12-16-2010, 03:59 PM   #9 (permalink)
View Kabal's Photo Gallery
I too have just had this happen to my 2009 Corolla.
Ironically, my fiancée has this problem on her 2008 Yaris too. After some preliminary checks I found that the ABS brake sensors in the yaris models have connectors and wiring harnesses that have lots of corrosion issues. I believe there have been TSBs issued on the issue with the yaris, but no recall. The parts required for this are expensive.
Hopefully, you are still under warranty like me. I must say, with these issues you start questioning if Toyota quality is above the rest at all, or just like most every other dealer..
I would go test your ABS somewhere, after verifying brake fluid and the fuse for the brake system, of course. I suspect that it will not work, just as mine (and my fiancées) doesn't anymore. What a week for brake troubles to happen in both cars!
Kabal
DD: 2009 Corolla XRS - Magnetic Grey Metallic
ALT: 1997 4Runner SR5 - LED Dash Lighting, DPX501 HU, Clear Signals & Corners
Kabal is offline   Reply With Quote
Old 12-16-2010, 09:33 PM   #10 (permalink)
Diehard Rams Fan
The problem is that when we post every little thing on the forum it appears to be a worse issue than in reality. It may happen to only one of us & to less than 1% of owners but as we talk about it it seems to be a bigger issue. Trust me, every brand/make forum has things like this that come up. After all, it's a machine & some things do happen.
Old 12-19-2010, 08:26 PM   #11 (permalink)
Got it fixed today, it was sensor malfunction!
