2010 Corolla trunk liner removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2010, 09:14 PM   #1 (permalink)
View cswaite's Photo Gallery
Does anyone know what the proper tools or method of getting the trunk liner fastener pins out, it has two slots on each side which looks like screwdrivers could be put in and pop the pin out but im afraid to damage it. thanks for any tips or advise.
When I say trunk liner i mean the fabric walls of the trunk not the lower portion cardboard that is the floor of the trunk.
cswaite is offline   Reply With Quote
Old 12-15-2010, 09:26 PM   #2 (permalink)
2010 Corolla S
Gameroom cash: $230908
View TFCommanderBob's Photo Gallery
I could be incorrect as it has been a while, but cant you pop the fabric around the head?
TFCommanderBob is offline   Reply With Quote
Old 12-15-2010, 09:34 PM   #3 (permalink)
erm...i just tried and i dont think you can. ill probably just get a cheap U shaped panel tool, that will probably be the best method to prevent messing it up that I can think of.
Old 12-15-2010, 09:49 PM   #4 (permalink)
The Corolla That Could
shotgunjimmy's Avatar
Gameroom cash: $213000
View shotgunjimmy's Photo Gallery
USA
I doubt this would work in the trunk. The trunk liner is pretty stiff. However, this method works for the fasteners behind the rear seats.
As for removing the trunk liner clips, I use a flathead screwdriver. Just make sure youve got it inserted as far as it will go and take your time. Try and work both sides if you have to.
Hope this helps.
2009 Corolla S : Kenwood Kdc-x993, Polk MMC6500, Polk db651, Rockford Fosgate T110D2, Alpine Pdx.5
Magnaflow 2.25" Muffler, TWM Short Shifter and Base Bushings, Summit Engineering Shifter Cable Bushings, Tein S-Techs, V-Leds LED's, Enkei RPF-1 (18x8 +35), Inno IN-SU Roof Rack.
shotgunjimmy is offline   Reply With Quote
Old 12-15-2010, 09:50 PM   #5 (permalink)
Gameroom cash: $457387
View cabur's Photo Gallery
I use a tie-wrap. Poke it through, fold it and pull the ends together with a plier. Also a small flat screwdriver will also work. Just put it through the opening and lift.
LE, Smart Key, Limousine tint, Back-up sensor. M.I.C. 7" DVD.
cabur is offline   Reply With Quote
Old 12-15-2010, 09:51 PM   #6 (permalink)
http://www.trademotion.com/partlocat...layCatalogid=0 this should help you should you break few of them.
Old 12-15-2010, 10:06 PM   #7 (permalink)
what car? Im just a Tech
ploud's Avatar
View ploud's Photo Gallery
you can use a small flat head screw driver as long as you pull evenly outward without tilting and try to finest it not force it. i removed all of that kind of fastner but if you dmage it you can buy it from the dealer for a few dolllars
ploud is offline   Reply With Quote
Old 12-15-2010, 11:17 PM   #8 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342266
iTrader Score: 7 reviews
You guys should all spend a few bucks & get the proper tools. The right tool can make any job simple. I bought this set years ago & it has worked perfect & I've yet to break a clip.
Amazon Amazon
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 12-16-2010, 05:27 AM   #9 (permalink)
Gameroom cash: $157000
View pinoyesv6's Photo Gallery
http://www.amazon.com/No-Scratch-Tools-Removing-Fastener-Molding/dp/B000LNBLTK/ref=sr_1_4?ie=UTF8&qid=1292476553&sr=8-4
i got a similar set from harbor freight. it is like $3 and so worth it.
pinoyesv6 is offline   Reply With Quote
Old 12-16-2010, 06:57 AM   #10 (permalink)
Lowdown Lowlife
FlawedLegacy's Avatar
Gameroom cash: $1249500
iTrader Score: 14 reviews
View FlawedLegacy's Photo Gallery
Harbor Freight FTW!
any small pry-bar will do or flat head screwdriver if going the cheap way
2009 Magnetic Gray Metallic Corolla LE
^Click For My CarDomain Page^
Team HAMSTER
FlawedLegacy is offline   Reply With Quote
Old 12-16-2010, 07:06 AM   #11 (permalink)
if you wanted to go cheap and wanted to use something you already have, i wouldn't use a pry bar or a flat screwdriver. problem with those tools is that you can only pry on one side of the head.
when pulling the pins out, i usually used a v-shaped pry tool since it distributes the force on more than one side of the pin head this reducing the risk of breaking the head.
with that said, if u wanted to go cheap, an old fork would be better than a screwdriver.
Old 12-17-2010, 10:57 AM   #12 (permalink)
Thanks for all the input. I ended up ordering one of these off ebay for like $5, hope it will do the trick. If not i'll look into other options. Thanks again for all the input.
Old 12-17-2010, 11:12 AM   #13 (permalink)
Lowdown Lowlife
let me know how easy it is... with father-in-law and I constantly rebuilding cars, this may be a nice present for him.
Team HAMSTER
Old 12-17-2010, 11:21 AM   #14 (permalink)
Toyota Addict
Gameroom cash: $190660
View clintj's Photo Gallery
If you break them instead of buying over priced dealer replacements just go to Napa or other local auto parts store and buy a bag of similar sized and replace them all so they are not mismatched. I believe Napa may even have the exact ones for our deck lid liner.
And yes the plastic remover tools are the way to go for those. For tighter places they make metal ones with rubber handles.
clintj is offline   Reply With Quote
Old 12-22-2010, 11:55 PM   #15 (permalink)
Just a heads up for those interested in knowing, I just received the tool I ordered and had no problem removing the fasteners without breaking them, there are a few that are in tight spots that I may need to use screwdrivers or something else to get to. The tool is definitely good though. Thanks for all the advise.
