XM Tuner 86180-0W032 pinout - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2011, 10:06 PM   #1 (permalink)
View Frank_005's Photo Gallery
Hi, I have factory radio with XM tuner. I want split my connector after the xm tuner to take audio and acc. I install amp and subwoofer and do not lose my 6 factory speaker. (dont want line out converter on my rear speaker) Somebody have the pinout of the XM wire?
Frank_005 is offline   Reply With Quote
Old 01-24-2011, 06:00 PM   #2 (permalink)
Older fart
dbennett48's Avatar
View dbennett48's Photo Gallery
USA XM Tuner Pinouts
It appears in my Factory Service Manuals that XM radio is included inside of the factory radio system. I can not find an external XM Radio box. Sorry I could not be of more help. By the way the radio talks to other boxes using ATX-LAN format; that is a serial feed back and forth. Good Luck!
2010 Toyota Corolla S, automatic, leather seats, XM radio and Bluetooth. Pivot 3 Throttle Controller just added. My first Toyota.
dbennett48 is offline   Reply With Quote
Old 01-24-2011, 07:04 PM   #3 (permalink)
no, It's not option, XM tuner = 300$ with installation kit. It's not my question.. Thanks
Old 01-25-2011, 11:07 AM   #4 (permalink)
View sienna1's Photo Gallery
Canada
If you were to do that and assuming that the ACC (switched +12volt) feed can safely support the additional current draw, you would only have access to the satellite audio to feed the sub-amp.
sienna1 is offline   Reply With Quote
Old 01-25-2011, 12:16 PM   #5 (permalink)
Perfect, this is what I want. I only listen sat radio.
Old 01-25-2011, 02:29 PM   #6 (permalink)
Canada
USE AT YOUR OWN RISK!!!!! Looking at the connector (12pin) on the XM tuner (NOT the connector on the harness), the audio signals are on pins 2, 3, 4 and 5 (pin2=L- , pin3=L+ , pin4=R- , pin5=R+ ); the ACC +12volt is on pin8. Pin1 being the first pin on the left of the top row and pin7 being the first pin on the left of the bottom row. Note, the connector's bottom edge corresponds to the area with the tuner's labels. Before making any connections, please verify the information.
Old 01-25-2011, 07:30 PM   #7 (permalink)
SUPER, I try this at spring. Too cold now!
If you find this adaptor made by Toyota or other, PM me please.
