The stock cat will give plenty of flow so no need to upgrade that unless you are going for HUGE power (big boost) and trying to keep it street legal. Here is the full system layout:
Header, factory cat, mandrel bent stainless pipe of the same diameter of your axleback between your cat and rear section.
No need to take it beyond that unless you are going big power and the exhaust is your choke point. I haven't looked at how restrictive the factory system is so I am not even sure that the center section needs to be replaced. Work and the 8 month old is keeping me pretty busy and I haven't had the urge to crawl under the car in -10F weather with 15 inches of snow on the ground.
