This connector is a tricky one for sure. If I remember correctly, you have to press the tab and slide the connector out. There is a collar on the top of this connector. You've got to press the tab, slide the collar back (away from the plug), and then the clip will come out. The collar is rectangle in shape.
I know this doesnt do much good without pics, but it's all I can do for now.
Good Luck!
2009 Corolla S : Kenwood Kdc-x993, Polk MMC6500, Polk db651, Rockford Fosgate T110D2, Alpine Pdx.5
Magnaflow 2.25" Muffler, TWM Short Shifter and Base Bushings, Summit Engineering Shifter Cable Bushings, Tein S-Techs, V-Leds LED's, Enkei RPF-1 (18x8 +35), Inno IN-SU Roof Rack.
