OK not trying to sound harsh or trying to be rude but this is how i feel about this.
Do most of you that post on this thread actually read the topic completely before chiming in your 2 cents?
this thread has noting to do about loosing traction or getting better tires. we are not discussing about shocks, sway bars or such items. we are not talking about driving on winter or ice. we are specifically talking about where we can find a LSD that will work for an auto tranny.
We already established that the TRD LSD is for 5 speed manuals no point of saying TRD don't make one for auto.
Saying things like LSD is not as effective on front wheel drive compared to rear wheel or AWD is a bit ignorant.
Do most of you even understand how LSD works and how many different types are available for different applications there are?
You do understand Toyota already have a pseudo limited slip with the use of VSC and Trac control on the corolla without the TRD diff. which works by using the ABS to control your slipping tires by reducing power. you loose power and it hammers you until you take your foot of the gas. not much fun when it goes of during curvy driving.
A Torque Biasing Differential in a front wheel drive car can put down power on a twisty road, and reduces torque steer by driving fast around sharp corners while on full throttle. this type of LSD allows the front axles to spin like an open differentials while proving better traction because it allows the two tires to spin in different speeds to reduce the chance of plow effect that you would get if you had a locked diff. I know you can not drift with a front wheel drive but you can still push through if you know how to drive. I don't care how good your tires are when you loose grip your not going to gain it back unless you either stop or reduce power especially with an open diff. you have a better chance keeping tire grip when you have a true LSD, which makes it fun to drive front wheel drives especially when there is no VSC/Trac.
if you just like to post random stuff that has no bearing to the topic we have general chat for you to write on.
thank you and stay on topic, keep your opinion to yourself if its not going to help us to find a LSD that will work on the auto tranny because you are just a distraction and cluttering the thread. this is not meant to hurt your feelings
