Driver's door clunks and grinds when opeing and closing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2011, 07:50 AM   #1 (permalink)
View spec seven's Photo Gallery
Has anyone experienced a problem like this? Something inside the door mechanism is making the noise. Would this type of problem be covered under warranty? The car has about 35,000 Km on it.
Thanks
2010 XRS
spec seven is offline   Reply With Quote
Old 02-22-2011, 08:14 AM   #2 (permalink)
Lowdown Lowlife
FlawedLegacy's Avatar
Gameroom cash: $1249500
iTrader Score: 14 reviews
View FlawedLegacy's Photo Gallery
door should not be doing that... is it INSIDE the door or like the hinge/etc making noises? More details would help. What kind of noise, etc.
Depends what it is if it is warranty or not. If it's an internal issue, it should be covered.
2009 Magnetic Gray Metallic Corolla LE
^Click For My CarDomain Page^
Team HAMSTER
FlawedLegacy is offline   Reply With Quote
Old 02-22-2011, 08:19 AM   #3 (permalink)
Unofficial TN Member
Shft99's Avatar
Gameroom cash: $444285
View Shft99's Photo Gallery
Wd40
2009 Corolla S | Magnetic Grey Metallic
Shft99 is offline   Reply With Quote
Old 02-22-2011, 08:57 AM   #4 (permalink)
It's the mechanism that stops the door from swinging after you open it. The crunching and grinding is from inside the door, under the panel.
2010 XRS
Old 02-22-2011, 09:29 AM   #5 (permalink)
Lowdown Lowlife
did you door get hit or anything?
Team HAMSTER
Old 02-22-2011, 09:39 AM   #6 (permalink)
A while back a dog ran into my car an did a little damage to the lower part of the driver's door, but I don't think it was enough to cause damage to the inside. I think I'll just book an appointment and bring it in and hope that it's covered under warranty.
2010 XRS
Old 02-22-2011, 10:02 AM   #7 (permalink)
Lowdown Lowlife
I would try some WD40 first just to make sure it's not just a squeak or something minor, but yeah, next step is to isolate the issue.
Team HAMSTER
Old 02-23-2011, 05:32 AM   #8 (permalink)
Toyota Addict
Gameroom cash: $190660
View clintj's Photo Gallery
Was the damage repaired? If so take it back to the shop who did the work.
clintj is offline   Reply With Quote
Old 02-23-2011, 06:10 AM   #9 (permalink)
May the force be with you
Skipandrun's Avatar
View Skipandrun's Photo Gallery
i dunno if this the same that happend to me but it clunks everytime i open and close the door, what i noticed is the bolt or screws in the middle (where the black color lever is, i dunno what they called it)are loose. So i just tighten it up and voila!
Skipandrun is offline   Reply With Quote
Old 02-23-2011, 08:00 AM   #10 (permalink)
on full afterburner
Gameroom cash: $1347897
Your door might come out of alignment from the impact, take it to the dealer and get them to adjust it if you're still under warranty.
